Peter Poddy
I had them cranked down so tight I thought the straps would snap but it was pointless. They were binned in the end.
I hope not literally, what a waste! As I say, they’ve worked used on the above (+ 3 MTBs and one utility bike for last 6 years) They shouldn’t require over-tightening as the oval rubber pad is designed to prevent them slipping.
For you to have repeated problems sounds like a poor setup. If you get the webbing strap in the wrong place (this is the fiddly bit for me, took a while to get it right first time) it can get between the oval rubber pad and your seatstay/fork, and then no amount of tightening will get it to stay. I suspect other wrong strap/rubber grip configurations would also compromise the fit..
If set up correctly and cinched firmly (not crazily) using the long ball-jointed hex-key I see no reason why you had the problem. The biggest problem I’ve had is getting them off, always seem to get the strap to wrap in on itself. When attempting fitting to the Vagabond I initially thought they were incompatible, even put them up for sale in a huff. A riding buddy (who is also good with puzzles!) intervened, had a bash and turned out they fitted perfectly.
Technique is definitely an issue with these, but I can’t surely have just gotten lucky with fitting/using succesfully to five different bikes?
