I’m getting really cheesed off with this! Any further thoughts before I cut my losses, stick them on ebay and get some Shimanos?
I bought the CPS hardware pack mentioned by Stato, above.
I’m using a 20mm post mount, with the longer screws, and CPS washers either side of the caliper.
And still…the damn rotor is too deep in the caliper, and hits the top of the rotor (where the pin holds the pads) on the way around. It’s almost as if it needs an additional spacer.
The 180 rotor is a wave design. The previous 160mm (which worked fine) was more rounded. Could rotor design make a difference (assuming it’s the right size)
Please can anyone shed any light on WTF is going wrong? The neighbours must wonder what all the late night swearing coming from my garage is….
