I’m wondering whether Thames Water have fed me some BS.
We have a “flow” issue – its a bit limited at 5l per hour. Despite there being one of those small square metal hatches in the footpath outside the house, Mr TW told me that the only way to turn off the water is to heave up the lovely flooring that a certain Mr Darcy installed, and find the mains tap.
Until now, I’ve understood it to be the tap at the back of the house in the kitchen, on a vertical pipe that runs vertically from the floor to the loft where the tank used to be, which is now extended and runs across the loft and down into the back of our boiler. Assuming this pipe comes from the front of the house, it would run parallel to where the outside TW hatch is. Turning this tap off turns water to all taps and the boiler off.
The reason he mention it is he thinks the flow restrictin is cause by build up in an internal pipe.
So, why couldn’t I open the small square hatch in the footpath and turn of the supply to my house?
