Im looking for something like the DMR tension seeker 2 roller – without splurging 30 odd note on the whole kit to throw half of it away.
Mooching around on the interweb reveals no bother getting the orange/black nylon “MRP” style rollers but for this purpose i need 2 that look like the roller on here. – and it would be even better if the side plates were nylon to keep the noise down , like the old DMR lower BB mounted guide used to be.
Has anyone seen these for sale on their own on their travels ? the same things used on surlys tensioner but still i cant find spares on their own.
I could whip something up with a couple of jockey wheels and some washers how ever its unlikely ill find washers with the correct ID for a snug fit on the axle and it’ll rattle like a bam (although this will be a last resort)
Dutchbikebits had a bunch of recumbent roller options that have come up trumps for what i want 🙂
My chainruns huge and chain hits the frame on bumps . Does my napper in , factory solution is a 150 quid set of rollers- that looks like something someone in yorkshire knocked up in a shed.
basically use the drill press as a lathe to hollow out some skateboard/skate wheel- reckon if i turn the inner OD down to the ID of where the bearing sits in an aftermarket jockey wheel or small cassette cog – then cut the wheel in half , then press it onto what ever cog i use – then araldite it back together sandwiching the cog between the 2 halfs of the wheel as a guide. – or screw or any number of methods of fixing it ….
job would be done and should be quiet to boot – PU should be quieter than nylon as well.
Posted 7 years ago
Viewing 5 posts - 1 through 5 (of 5 total)
The topic ‘where to source a couple of "idler rollers"’ is closed to new replies.
