I'm old fashioned probably….but I've 2 sets of wheels (717, dt comp, hope xc and ex721, dt comp, goldtec draco) biult 36 hole as to my mind 4 more spokes weigh next to nothing, increase the strength massively, make retruing a wheel after a problem easier, and make a single broken spoke at the start of an enduro nothing what-so-ever to worry about.
Using the same logic I was going for 36 hole again with this new wheel, and yes it is a rear.
hmm. I may need to rethink and go for 32…from my chat to BETD getting a 36 hole rim is an issue….maybe I should not make this problem worse by buying another 36 hole hub.
maybe i should start stocking up on 36 hole rims! Then again…I'm buying this new wheel because the hub finally died on an old wheel, not the rim.
