Viewing 8 posts - 1 through 8 (of 8 total)
  • Where to buy tubing for bleeding disc brakes?
  • Mrab
    I need some clear tubing approx 3mm inside diameter transklucent for bleeding my disc brakes. What shops can I buy this from?
    I was thinking home brewery??
    StuF
    windscreen washer hose – little car bits shop ~£1/m
    seanodav
    Fish tank airline from local aqaurium shop
    kenneththecurtain
    B and Q have rolls of different thicknesses. I took a brake in to get the right fit, think a metre was less than a quid.
    snowslave
    I got some from a bike shop, along with a syringe
    spooky_b329
    Get the size you think and one either side as well…easy to get the wrong stuff plus it stretches a bit so you want a nice tight fit 🙂
    carlosg
    Tube from a knackered camelback(or similar) and use a cable tie to restrict the end that goes over the bleed nipple(make it a tight fit)
    retro83
    halfords do it, prob cheaper elsewhere tho
The topic ‘Where to buy tubing for bleeding disc brakes?’ is closed to new replies.
