Viewing 10 posts - 1 through 10 (of 10 total)
  • Where to buy Shim Washers
  • 5lab
    Hello
    I’m doing some tuning (bodging) to my fork, which involves changing some washers to a shim stack. For the bodge, I’ll need a selection of washers, with a 10mm inner diameter, a selection of 12-18mm outer diameter, and 0.10mm thick. Does anyone know where I could buy this kinda thing? It seems too specialized for a regular diy store
    Thanks
    Hugh
    LoCo
    which forks?
    5lab
    marz 55 air TSTs. the bits I need are just generic washers though
    LoCo
    Yes have marz shims in stock, drop me a mail with all items needed and I can quote you. 😀
    Simon
    5lab
    thanks! YGM (via the message thingy on your website)
    racing_ralph
    can someone explain this in simple terms for me please?>
    LoCo
    Piston in forks has a stack of washers (shims) these are of varying size (diameter)and thickness by adjusting these your can change characteristics of the damping e.g less low speed but more high and mid speed.
    Stacks can be utilised for both the compression and rebound circuits, however ever unit is different in how these are arranged.
    Could write a pretty big article on this but too busy at the mo, hope that explains it basically.
    racing_ralph
    makes sense aye
    organic355
    cant you just wash your shims yoursen?
    Simon_Semtex
    Get a copy of “Zen and the art of motorcycle maintenance” now.
    Coke can and a pair of scissors should do the job.
The topic ‘Where to buy Shim Washers’ is closed to new replies.
