Thinking about this a bit more,from a truck mechanic’s point of view, I’m guessing that system is the best they could come up with using a single pipe between wagons.
A basic two pipe system, as used on trucks since the 1930s would be an improvement.
As would spring brakes, as used on trucks since the 1960s.
Another problem that comes to mind, is that all wagons in the train are braking equally, whether they are loaded or empty. This means that either the empty ones will lock their wheels under braking, or the loaded ones will not be braking as hard as they could.
A simple mechanical load sensing valve as used on trucks since the 1970s would solve this.
As would ABS, as used on trucks since the 1980s.
Better still, considering the length of a train and the time it takes for a variation in air pressure to travel from one end to the other, EBS, as used on trucks since the 1990s.
As long as they stick to 100 year old technology, articles about train brakes are always going to have to explain what causes runaways, while articles about truck brakes don’t.
