- This topic has 96 replies, 45 voices, and was last updated 10 years ago by aracer.
when is an engineer not an engineer?
DugganFull Member
hekingisdead – Member
Read this this morning. Am I alone in being a little concerned that an individual can be castigated so publicly by the CEO of a company so soon after the event!? I don’t believe a thorough investigation into the incident can be concluded so quickly.Quite right.
These were my first thoughts as soon as I read the article, it seems pretty poor form and not well managed at all. Surely until they know 100% what the fault was they should just keep schtum. Instead of saying ‘we think it was the engineer’ and then going on to imply he’s a liar as well.
igmFull MemberWrecker – you need to read the second half of definition 1 you posted. The bit about qualified and professional.
Personally if I want something machining, then perhaps a machinist or fitter is required – probably not an engineer, they wouldn’t be much use.
But as someone once didn’t say – an engineer by any other name would smell just as sweet – so who cares.
I’ve had my CEng for many years and if I ever get round to it I’ll get my FIET pretty easily – but I’m more manager than engineer these days. Of course so was Brunel.
They pay me enough that I don’t care whether I’m an engineer or not.
gofasterstripesFree MemberI though on trains the brakes were held off by the air, so in the event of a failure the thing STOPPED rolling? I cant check right now, maybe someone can explain?
wreckerFree MemberThe bit about qualified and professional.
Yep, it says especially, not exclusively. It also doesn’t say or suggest that qualified or professional means graduate or chartered.
Precisely my points. The satisfaction of the job, the sense of accomplishment and the earnings should be plenty to be proud about. The post nominals tell everyone what they need to know. Hijacking the word “engineer” is just pathetic and elitist.
I’ve seen this from more sides than most, having completed an apprenticeship, been a hands on engineer then working up through college and university to an office based engineer (although I’m no designer). I’ve worked for tiny firms with a dingy office and some blokes in vans and also for huge global engineering consultancies.
I was working with a “plumber” yesterday who was calculating gas supply pipe sizes and purge rates. Something the design engineer (not being gas safe qualified) wasn’t qualified to do.
richmarsFull MemberI though on trains the brakes were held off by the air, so in the event of a failure the thing STOPPED rolling? I cant check right now, maybe someone can explain?
A big spring holds the pads against the disk, and air pressure is used to move the pads away from the fail safe position.
gofasterstripesFree MemberSorry, I mean if that’s the case why did it roll away?
maxtorqueFull MemberThe issue, for those that might have forgotten is that nothing is 100% safe.
Everything is designed to a level of risk. In this case a series of events meant that the design level was insufficient. However, how many trains have been shunted around the US rail system between every failure? I bet it’s hundreds of millions, so at what point do we call it safe???
It is of course perfectly feisable to design a system that is 99.9999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999% safe, for example, we could fit square wheels and weld the carriages to the tracks at EVERY stop, but unfortunately that would cause more disruption (and probably more deaths in the long run) than this accident.
These days people seem to forget than a) they aren’t immortal and b) they are not infalible
aracerFree MemberPrecisely my points. The satisfaction of the job, the sense of accomplishment and the earnings should be plenty to be proud about. The post nominals tell everyone what they need to know. Hijacking the word “engineer” is just pathetic and elitist.
So how would you feel about somebody who does sports massage calling themselves a doctor? Somebody who does filing calling themselves a lawyer? A teaching assistant calling themselves a teacher?
wreckerFree MemberSo how would you feel about somebody who does sports massage calling themselves a doctor? Somebody who does filing calling themselves a lawyer? A teaching assistant calling themselves a teacher?
Well that’s a completely different scenario. The definition of the words clearly prevent anyone doing this. The definition is the word engineer is also very clear. Read the thread.
You also suggest by the examples that hands on engineers are somehow less skilled or trained than graduates. I can assure you that this is not the case.aracerFree MemberYou’re suggesting to me that a “gas heating engineer” has as much training as a professionally qualified engineer? You do presumably realise that there is a lot more to being professionally qualified than a BEng?
Or are you suggesting that a sports masseur is less skilled than a doctor?
wreckerFree MemberA 4 year apprenticeship isn’t uncommon. That’ll be a minimum of a 40 hour week, too. No free periods.
As you suggesting that someone who does filing is not less qualified than a lawyer?
aracerFree MemberYes, I have experience of what apprenticeships involve, and how they compare to professional engineering qualifications. Do you?
I actually have a lot of respect for people who’ve done apprenticeships, but most of those don’t call themselves engineers. Do most people calling themselves engineers even do that much?
er, yes, in the same way a “gas heating engineer” is a lot less qualified than a CEng.
brassneckFull MemberI’m fairly sure that engineer is a protected term in Canada, as I thought this was where the stink was originally kicked up over Microsofts MCSE qualification in its original acromyn (MS Certified Systems Engineer) – the acronym is back but it stands for something different now.
Beng but not engineer 🙂 – now I get called ‘architect’ which is even more perplexing to be honest.
muddydwarfFree MemberThe guys i work with in a busy tool room call themselves engineers, all timed served with decades of experience.
You are welcome to come round and explain to them why they aren’t engineers.. 😉
veedubbaFull MemberI had a bit of a ding dong with someone on here a while back about the term “engineer” but I couldn’t find a link (in the 10 seconds I spent looking).
I agree that letters after your name do not make you any more qualified than someone who has many years time-served, but that allowing the free use of the term devalues it to the point that the “tv engineer” that came to run a cable for me couldn’t explain how it worked or how to get it to work when it was broken.
If it was a protected term, then at least there’d be some prevention of its devaluation.
FWIW, I think that an engineer is in the most general term is a solver of problems and someone who understands fundamentally how things work (what those things are depends on what sort of engineer you are): you don’t need a degree for that, but you do need a brain that works in a certain way.
And I also think that it was very suspect of the CEO to point the finger at the guy so early into an investigation.
paulpalfFree MemberBrassneck is right about the term “engineer” being protected in Canada, but I think it varies by province. Here is BC it is protected by APEGBC, the body who manage P.Eng, the equivalent of a charter in the UK(I’ve had both). However, it isn’t really enforced – I am the only “real” engineer in my department of about 10 people!
I am curious about this idea of the brakes being held off my the air, and how cars could roll away if the air was shut off.
wreckerFree Memberer, yes, in the same way a “gas heating engineer” is a lot less qualified than a CEng.
Not if it’s to do with gas or heating, he’s not.
FFS read the thread!
igmFull MemberYou also suggest by the examples that hands on engineers are somehow less skilled or trained than graduates. I can assure you that this is not the case.
Wrecker – there is a difference between less skilled and differently skilled. There’s plenty of stuff that craftsmen, like the plumber you mentioned, have the skills for that engineers don’t.
But to take another example, craftsmen (electricians) regularly design the wiring for people’s houses; however by follow standards (well they should do anyway) that were written by engineers (of the chartered variety normally) and published by the IET (a well known institution that offers a route to chartered status with he Engineering Council).
Now, please don’t ask me to wire a house, I’d be a bad choice, but if the wiring regs need rewritten, I’m the sort of guy you need.
Incidentally, IIRC there is nothing to stop you acquiring premises on Harley Street and calling yourself a doctor (though my view is doctors are people with doctorates – not MBChBs – if only to wind up certain people I know).
Now, chips off shoulders everyone and go earn some money.
PS I read your definition Wrecker – the especially applied one to the professional bit, not he qualified bit.
CougarFull MemberMy job title is “Specialist Engineer” – not my choice, that’s what HR say I am.
If “engineer” hypothetically became a protected term, what do I call myself? Technician? The people who pick up the phone and ask you if it’s plugged in and switched on are technicians.
I don’t design computers or even really implementation systems to any great extent (or at least, it’s not my primary role), so I’m not really an engineer by some folks’ definition. And if I did I’d probably be an Architect, which is even more confusing.
I think the problem in IT is it’s a relatively new industry and it’s borrowing existing words to cover new “similar” roles. Maybe we need some new words. In conventional engineering terms I’m probably closer to the IT equivalent of a mechanic.
In the meantime, “Engineer” is probably the closest match to what I do. If you’re a ‘real’ engineer need a protected title, maybe “Professional Engineer” or “Chartered Engineer” (which already is IIRC) is what you seek there.
wwaswasFull MemberAs above, I think it’s what goes in front of the engineer bit that’s important.
I wouldn’t expect a ‘proper’ engineer who’d spent their whole lives designing car engines to suddenly be able to do all the engineering required to build the Hoover Dam. It’s a different job that requires a different type of engineer.
buzz-lightyearFree Member“to me an engineer is someone who physically builds stuff like steam trains or something. Machining stuff to designs, assembling, fixing. “
This is the problem.
My dad was a very good Precision machinist and mechanic. He would have made a very good Mechanical Engineer. I’m an Systems Engineer ( and chartered). The press refer to me as a scientist or simply a “Boffin” uurgh!
chiefgrooveguruFull MemberThe way I see it is that scientists work out the idealised theory. Engineers take that theory and work out how to apply it in the real world so that products can be designed. Draughtsman may do the drawings, machinists and technicians and mechanics or whole production lines etc may turn the engineers’ designs into physical items.
A great engineer understands the whole process from theory to finished product and can do all the hands-on work too but the key role being able to design the item using their knowledge of engineering theory (and the great thing about engineering theory is that it is very practical because that’s the whole point of engineering!)
I wouldn’t expect a great machinist or scientist or draughtsman to want to claim they’re an engineer because they understand the division of knowledge, skills and labour, and are proud that very few engineers can do what they do.
In the B2C environment any old vaguely technical job seems to get labelled a “xxxx engineer” in the UK. I understand that this is not so much the case in the rest of Europe where the term “engineer” carries some more weight (and the salaries tend to be better too!)
projectFree Memberwill assume you are aware of (P)FMEA’s?
I’m wondering if “driver forgets to apply brake” was included when they did (?) the FMEA on this system?!?translation required
RichPennyFree MemberFMEA is a process designed to consider how things can potentially go wrong and how these risks can be understood and averted. His point being that human error can be expected, so fail safe systems should be in place to prevent accidents where possible.
footflapsFull MemberFMEA Failure Mode and Effect Analysis
You basically sit down and go through all the known and all you can think off failure modes and work out what can happen and then, in theory, try and mitigate them by changing the design / operating procedures etc. Eg what if the power fails, what if the driver takes a leak in the cabin etc etc….
MidlandTrailquestsGrahamFree MemberMy bike, in my parking space at work, with neither of its two independent braking systems applied.
And can we go back to this bit, it’s quite important…
“I though on trains the brakes were held off by the air, so in the event of a failure the thing STOPPED rolling? I cant check right now, maybe someone can explain?”
“A big spring holds the pads against the disk, and air pressure is used to move the pads away from the fail safe position.”
“Sorry, I mean if that’s the case why did it roll away?”
Lorries and their trailers have got spring brakes and breakaway valves.
If the lorry loses its trailer, the trailer brakes are immediately fully applied.Why don’t trains do that ?
falkirk-markFull MemberI think the CEO beggars belief, If what he does say is true is his company not negligent through employing someone not suitable for the task or not a suitable training regime in place for the employees.
aracerFree MemberNot if it’s to do with gas or heating, he’s not.
Ah, OK – can I change my answer to the previous question then?
Not if it’s to do with filing, or probably typing.
I did, including the bit where you appear to claim that 4 years working 40 hours a week, which couldn’t all really be described as “training”, is more training than that required for a professional engineering qualification, hence the question.
jag61Full Memberlike my boss used to say ‘yesterday i couldnt spell engineer but today I are one’ not even funny 30 yrs ago. He was a ‘proper’ structural engineer btw not the mud and wire kind 😉
convertFull MemberFix or install stuff with moving parts – Mechanic
Make stuff for one machine on another machine – Machinist
Do sums and other clever things that makes stuff work – Engineer
Colour stuff in – Designer!
Proud to be(by qualification, although I now teach colouring in which is even worse!) a fully paid up member of the last category! I have secret envy of anyone who is good at the previous 3.
bigblackshedFull MemberWell, by the definitions that some of the above are using, I’m not an Engineer. Apprentice time served electrical / mechanical ………… builder, maintainer, modifier of machinery. My certificates for my qualifications say Engineer.
So that is what I am. 😉
aracerFree MemberFWIW bigblackshed, I don’t actually have a big problem with people who do the sort of thing I presume you do calling themselves an engineer – seems a fairly reasonable description (though convert did a pretty good job of defining stuff and you may strictly speaking fall into the mechanic category). However “gas heating engineers” and the like are generally technicians and installers.
GreybeardFree Member‘Architect’ is a protected name in the UK (you can’t call yourself an Architect unless you’re registered with ARB) – because they wanted to make sure the people who designed buildings so that didn’t fall down were competent – and at the time the law was passed, structural engineering wasn’t distinct from architecture. It’s a bit ironic that Govt now refuse to protect ‘Engineer’ or even ‘Structural Engineer’.
Re the big spring that holds the brakes on unless the air releases them – I also thought it was like that, but it’s more complicated:
gofasterstripesFree MemberYep – I’ll be reading the linked one next too. Ta.
EDIT:From that article: “Thus if a train comes uncoupled or an air hose bursts, the brakes apply fully, automatically. The amount of braking relies on the amount the system is charged however.”
So perhaps the train’s brakes were not yet fully charged as the firefighters turned the engine off that the Driver had left running to charge the brake system pressure up before that pressure was reached. Or it could be that the compressor/engine was holding the pressure against a slow discharge to atmosphere.
If there are also hand-actuated mechanical brakes on the cars [which I am sure I’ve seen in the UK] then perhaps he made a judgement call regarding the current brakeline pressure, the time for the pressure to complete it’s rise and also the number of the mechanical brakes he was going to hand-apply on the connected cars to ensure they couldn’t roll on the incline.
And in the end, it could be that his estimations did not include someone turning the engine off when they did.
MidlandTrailquestsGrahamFree MemberAs a truck mechanic, familiar with air brakes on trucks, trailers and buses, reading that article about train brakes, I was shocked to find the lack of what I would consider a fail safe mechanism.
As the article says, “A problem with the design of the standard air brake is that it is possible to use up the air in the auxiliary reservoir more quickly than the brake pipe can recharge it. Many runaways have resulted from overuse of the air brake so that no auxiliary reservoir air is available for the much needed last application.”
A simple spring brake, as used on all modern heavy vehicles, would solve that.
If you’ve ever seen a bus or lorry driver sitting there revving the engine before moving off, it’s because the air pressure has dropped and the brakes are locked on.aracerFree MemberIndeed – they call it “fail-safe”, but it doesn’t in the normal meaning of that word – ie there are some possible failures which will cause it not to work (OK with a brake which is sprung on the spring or the brake pad could fail, but they’re rather more unlikely occurrences than the auxiliary reservoir running out of air or a failure in the air pipe between the auxiliary reservoir and the brake cylinder).
GreybeardFree MemberThere’s a link (from the link I posted earlier) that’s specific to North American Freight Train brakes
http://www.railway-technical.com/brake2.shtml
This is more frightening than the first link – if you have leaks in the system and don’t top it up, you will reach a point where all the brakes release. Hence you have to use the handbrakes when parked (as is evident, you shouldn’t rely on keeping an engine running) but you can’t tell whether you have enough handbrakes, unless you release the air brakes – which takes time. It looks to me like a fundamentally flawed system that’s been patched and patched to try to make it more fail-safe, but every patch introduces more potential for errors.takisawa2Full MemberThere’s more too it than simple engine on – brakes applied or not. Any manner of events could cause it to runaway, but given that fire I doubt anything survived. 🙁
Very sad.
I’m currently filling out my iMechE application to become a MEng, but reading through the sample application they sent for reference I’m tempted not to bother. If what I read is indicative of what they are looking for then I’d sooner save my money. 🙁
The topic ‘when is an engineer not an engineer?’ is closed to new replies.
