Have this on the CX bike
Essentially you have punctures there can be no other cause [ unless someone in the house is messing with your bike].
It does deflate when you ride and if you used an accurate enough pressure gauge I am sure you could prove this
As its a [very] slow puncture IME you need to pump the tube up really really hard to find the little blighters. I also squeeze to increase the pressure of the bit underwater- it possibly only one bubble but always n the same place- tbh it might be easier to change tubes and be done with it.
I agree about testing the valves with wiggle as I have had that happen as well. Dont try and repair these. DOn’t get frustrated when your initial attempts to repair the valve and design ever more elaborate fixes either as it wont work…not that i would be this foolish 😳
