5thElefant
If you’re a big unit you need a lighter bike than the sacks on elbows and tendons have to level the playing field.
er, unless you can get bikes that have negative weight, then i think you are wasting your time tbh! What matters is power to weight ratio, as a bigger framed chap, i would expect you to be able to put out significantly more power than a racing snake, but if you still have a lower power to weight ratio, you’re still going to be going slower etc.
Also you are never going to be able to ride as light a bike as those racing snakes, because the bike will need to be stronger, and hence heavier to deal with the larger mass sat on it.
If you’re one of the big guys, and want to improve things, the best thing to do is just try to get out and ride your bike as much as possible, imo (exactly the same if you’re a racing snake who wants to improve in fact……) 😉
