Isnt 200mm in length just for a 200mm shock?
Not really sure what you mean there? There’s nothing on that link to tell you how long the coil is (and tbh it’s not that important).
It’s an odd way to list it, because the shock length is important as well as the stroke- for instance they list both 2 inch and 2.25 springs for 200mm shocks. Correct, but it doesn’t tell you which to use (200mm shocks commonly come in 50mm and 57mm, ideally you’d choose the 2 inch spring for a 50mm and the 2.25 for a 57. Though, might get away with mixing it up.)
By and large shocks have well established length/stroke ratios- in theory you could make a 9 inch shock with 1 inch stroke but in practice, a 9 inch shock will normally be 2.75, and so on. otherwise compatability would be a nightmare.
So, in turn if you buy a 2.75 spring, you don’t really need to know the length, because it’ll have been designed with a 9 inch shock in mind.
