• This topic has 56 replies, 34 voices, and was last updated 8 years ago by LD.
Viewing 17 posts - 41 through 57 (of 57 total)
  • Wheelsize rant – children
  • poah
    165mm crank was certainly too long for my 10 year old, even the 150mm thorn was slightly too long when I first got it.
    kids cranks
    LD
    So it’s done, a positive outcome to my rant 😉
    Just under 12kg and budget a bit under Islabike and well under Whyte, with a few garage bits!
    A big thanks to ads678 for the tip on the frame and to STW for the encouragement to build/assemble. Good fun with just a little stress.
    matt_outandabout
    Baggsie a go… The lad will be well pleased…
    I forgot you username..hadn’t realised it was you ranting!
    ads678
    That’s well nice. I might have to get one of those frames and stick in the attic for a couple of years!! 😀
    Did he help with the build?
    twicewithchips
    Mine are 4 and 7 – can we work out a deal when your lot grow out of these?
    T
    LD
    Will bear it in mind but got a pink 6 year old too so depends how into biking she ends up! Might have a Cnoc 14 for sale soon.
    matt_outandabout
    Easy to sort for H –
    Jason
    Thanks guys, I have just bought one of those Cube frames for my son. He is starting to outgrow his current 24″ wheel Kona frame. I was planning to build up a 15″ Be-One frame I have in the loft, but the size on the Cube looks better. Plan for the bike is 1×10, Reba forks and Crank Brother wheels, he seems to do well out of my old stuff! Photos in a few weeks.
    scottfitz
    wrong post!
    Jason
    Just to update the thread. I finally got my son’s cube built up and it was given it’s first ride today. The build was from a few bits I had in the loft, plus a new drive train and brakes. 1×10 using the Thorn cranks and a 28t Absolute Black ring. Final weight is about 8kg. Stand over is still a bit tight for him, but he will grow into it soon.
    He also needed a new helmet as his old one was cracked. Halfords sell a Bell youth helmet that is a nice match to the frame.
    peabrain
    Nice! Just finished mine today will have to take photos.
    matt_outandabout
    Sweet wee bike.
    uphillcursing
    If Mick R is about still I for one would love some more details/ construction photos. What tubeset? was there much extra bending involved to get clearances etc.
    zeesaffa
    This Cubes are great!!
    Also, just came across this:
    Sea Otter 2015: Trek Fuel EX-Junior
    elgolfo
    LD, interesting thread as I am doing something similar. What did you resolve for headset? I’m looking out for some air forks and am presuming tapered steerer could be accommodated with a tapered headset? Which forks did you go for & what what length steerer? Cheers for doing the graft and for other replies for sharing advice.
    Simon
    Did anyone buy a 16″ Cube Attention frame from BikeDiscount but now not need it?
    LD
    Probably far too late but only just spotted Elgolfo’s post.
    Headset is on of these – link
    Forks are – link with straight steerer. Air down at minimum, loads of movement and seem very plush.
    LBS cut a couple of inches off steerer and I put in a couple of 20mm spacers to raise stem up a bit.
    Also changed chainring to a 32t raceface NW in green.
    He’s quite enjoying it funnily enough! Just need more time to ride.
The topic ‘Wheelsize rant – children’ is closed to new replies.
