Getting the Solaris build underway – have decided to plump for the 27.5+ route to see what all the fuss is about.
Wrestling with options for the fork and wheels. Was all set for some Superstar wheels – with the 28mm ryde rims. And then they sold out with no known restock date.
Ideally I’d want a 30mm internal width, relatively light and less than £400 (or thereabouts).
And fork wise, I am going to run a 120mm. Was initially thinking Rockshox Yari – although am reading that they may not be so great on the small bump stuff and there’s a bit of a weight penalty. Not sure I need 35mm stanchions
Alternative being the Reba….although I wonder whether that will be too flexy.
Any others that may come into the mix and are easily serviced/spares available when needed?
on a bit of a budget again…..can’t really afford a pike!
