Need to clear out a few things, my room is a mess...
Hope pro2 20mm front hub with 32h mavic EX729 rim, and Hope XC rear hub with 36h d321 rim.
Not quite a matching pair, but close enough.
Bearings in the front are fine, rear had new SKF bearings about a month ago in the hub body itself (freehub bearings were fine)
£80 the pair
Mavic EX721 rims on white Reverse Hubs. 32hole, 36pt engagement. Believe these are the same as Ringle hubs.
20mm front, 150mm rear. In good condition overall, main fault is a bit of munching on the rear drive side where some imbecile hasn't adjusted thier limit screw properly and the chain has fallen off the inside of the cassette.
This has scratched up a few spokes pretty badly and taken a gouge out of the hub. Got the LBS to take a look and they reckoned it was only cosmetic though, so it should be ok. Front mint, rear has a few bits of anodising missing as can be seen in pics. Flash makes it look worse than it is!
£150 the pair
Pair of 32h yellow mavic EX721 rims. One is fine, the other has 2 dings. These could probably be straightened out easily enough, I've never bothered as I've never built them.
£25 the pair, or free with above wheelset.
2.7 slow reezay high roller, used.
£15
2.7 ST minion front, used
£15
2.5 ST high roller, very used.
£Free with anything else wheel-shaped.
2.5 Continental deisel, used
£5
Carts from an '05 66 RC, good condish. Forks hadn't had much use before I bent the steerer, doh!
Good as spares, or convert your SSV 66 to full HSCV plushness!
£??? offers, dunno what these are worth
Manitou Revox. Bit tatty. Bought 2nd hand and never fitted to my bike, seems to do the whole going in and out thing though, and holds air. 9.5*3 inch.
£50
Will swap/part ex any of the above for:
EX823 wheelset in 150mm flavour
170mm Hone cranks
When I have acquired the above, I will also have for sale:
150mm deemax wheelset
175mm old-style saint cranks
Plus a couple of other things to be added over the next few days
Based in Dundee, would prefer local pickup/meet somewhere but can post the bigger things if required.Can get more detailed pics if anyone wants anything.
Cheers, andy.
