I’m fitting a Wheels PF30 BB into a Stumpy carbon frame with BB30 X0 cranks with the spacing kit they provide and recommend is a bit confusing. They say:
Insert a 0.5mm spacer between the Integrated Preload Adjuster and the bearing seal on the non-drive side of the crank. In addition, replace the stock drive-side 8mm spacer with 7.5mm of Wheels Mfg spacers.
SRAM say that with a 73mm shell not to fit the 2 alu spacers, so why do they provide any with the Wheels kit? I’ve fitted the 0.5mm to the nds and torqued it up and chainline looks good and cranks clear the stays, it even spins freely. There’s a fairly big gap on the ds spindle, more than I’ve seen with GXP, is this because I’ve left out some spacers?
