Over 1800g according to this link (Unless there’s another set?)
that will be the old version, there’s a V3 version that’s a fair bit lighter. Stock will be hard to find at the moment I reckon.
Lots of people use crest hope hoops, as long as you are careful with your tire choice.
If you go much cheaper then you are not going to save much weight, and it is worth getting a light set.
I have just swapped out my croix de fer frameset for a tripster atr frameset – the tripster very smooth over bumps, but the cdf was less slack and so more lively and still pretty good over bumpy stuff and I sort of miss it. And I only saved 2.4lbs in weight as my build was 22.5lbs and the tripster is 20.1lbs.
