- This topic has 49 replies, 22 voices, and was last updated 11 years ago by aracer.
Wheelbuilders help – does it really matter if I lace to the "wrong" rim eyelets?
aracerFree Member
I’m lacing an A119 rim, where the eyelets have a small but definite offset to one side or the other, but they’re all flat in the rim. Does it actually matter all that much if I lace to the ones furthest from the hub flange, rather than the closest ones as you’d normally do? It would enable me to have the valve hole in the right point in the spoke pattern, which isn’t really all that important and I wasn’t going to bother with, but then I figured that actually which eyelet I laced to might not be all that important either. After all at one point Shimano made some wheels where the spokes were attached to the opposite sidewall of the rim (citing an improvement in stiffness from doing so).
Any thoughts?
StonerFree MemberI dont think Ive every used an offset rim.
I guess in calculating spoke lengths you can use a negative value in the offset box of the DT Calculator to reflect using the spoke on the other side of the rim.
Why cant you just flip the rim round?
scotroutesFull MemberThink about it…..
I’d say it was more important to get the valve at the right point in the spoke pattern, so make sure the hub is lined up accordingly
CheezpleezFull MemberDon’t be a fool, man. That’s how the dinosaurs were wiped out!
aracerFree MemberI dont think Ive every used an offset rim.
You probably have, but just haven’t noticed – which may answer the question itself. The offset is only 1 or 2mm to each side, and you have to look pretty hard to see which way. I don’t think it makes any difference at all to the spoke length required – though if anything it will help slightly as the spokes I have are on the long side (I’m reusing spokes – ironically the rim I’m replacing had a smaller ERD, so the spokes were even more too long for it).
Do you want a hint?
piedidiformaggioFree MemberIf you are doing it, you may as well do it right!
If you don’t, then the wheels will be unbalanced and as soon as you reach 20mph they will explode in a deadly fireball. Kittens will be severely injured, possibly killed and at least 4 children’s faces will be at risk. Ignore this advice at your peril!
StonerFree Memberas far as I can tell the rims Ive built wheels with dont advertise as having any offset: Mavic Open Sport, Salsa Gordo, Stans crest, Sun Equalizer
aracerFree Memberas soon as you reach 20mph they will explode in a deadly fireball.
20mph you say? Ah, that’s OK then – I won’t ever go that fast.
aracerFree Memberas far as I can tell the rims Ive built wheels with dont advertise as having any offset: Mavic Open Sport
I can’t comment on the others, but those definitely have the same amount of offset as an A119.
StonerFree Memberdear god that mavic website is terrible. But I cant seem to find anything about any offset save for referring to “Traditional Drilling”
takisawa2Full MemberMavic website is pants.
Why can’t they just give the bloomin nipple seat dia, rather than this stupid ERTD or whatever it’s called.
👿fourbangerFree MemberThat tiny offset over the length of the spoke will have bugger all difference on the spoke length. However, if it were me I’d be turning the rim round.
bencooperFree MemberIf it was my bike, I wouldn’t bother – if it was a customers’ I’d unlace it and do it again properly. HTH.
StonerFree Memberfrom the mavic tech site:
http://www.tech-mavic.com/tech-mavic/technical_manual/data/docs/products/2_104.pdf
http://www.tech-mavic.com/tech-mavic/technical_manual/data/docs/products/2_107.pdf
Interestingly the Open Pro diagram emphasises the angle of the hole where as for the Open sport and A119 there’s an almost imperceptible cant to the eyelet grommet.
scaredypantsFull MemberI’ve built literally
hundreds ofthree wheels in the past and I say …as long as the nipples still sit in the rim properly then it’ll be fine (and possibly a tiny bit stiffer as somebody said)
fourbangerFree Memberaracer » However, if it were me I’d be turning the rim round.
You’ve got to flip it 3 times or it won’t work though…. Keep up!
coolhandlukeFree MemberIt will probably make no difference but the rim will probably be slightly unstable. The centre bit of a rim will be under stress. The offset will provide a slightly greater area over which to distribute this stress. Buy lacing it incorrectly, the area to be stressed will be narrower but will gave the same levels of stress applied to it,
In an extreme situation, the rim would be more likely to twist due to this narrower zone.
Try balancing something on 2 fingers spread apart, now move your fingers in and try balancing the same object. It’s less stable.
It probably will never happen but I know if it was one if my wheels it would annoy the crap out if me until I relaced it.
Also, as someone above said, if a job is worth doing, it’s worth doing right.
chilled76Free MemberAs a regular wheelbuilder I’d like to re-phrase the original question…
I’ve built my first set of wheels and realised that I’ve gone to the wrong side ofset on the rim… Have I really got to unlace the whole thing and re-do it or will it be O.K?
It will be fine but marginally weaker and more resistant/difficult to true.
Next time, watch this as you go along as it will help you start so that you get the valve in the right place, (there’s also a second vid that follows it)
cynic-alFree MemberI’ve done it, works fine.
I’m building a Brompton dynohub wheel with hybrid snowflake lacing this way top just now.
bencooperFree MemberI’m building a Brompton dynohub wheel with hybrid snowflake lacing this way top just now.
You mean your spokes are too long 😉
clubberFree MemberI’ve done it wrong a few times, my excuse being that I was pissed when I built them. Empirical evidence suggests it makes no real world difference. One I know of is still going strong over 15 years later.
aracerFree MemberAs a regular wheelbuilder I’d like to re-phrase the original question…
Congratulations on your assumption. Completely utterly wrong on all points, but well done anyway.
I explained in my OP the reason for wanting to do this – it enables me to have the valve hole in the normal place. A fairly unimportant point, but something I’d prefer, and if lacing the rim the “wrong” way is equally unimportant then I might as well do that.
If it helps you to understand the need to do this, the hub I’m using only has the spoke holes countersunk on one side, so I don’t have complete freedom on how I lace the spokes in the hub, and the way the holes are offset is the wrong way round for the rim. As an experienced wheelbuilder have you ever had to build a wheel with a hub which only has holes countersunk on one side?
FWIW I’ve built about 10 sets of wheels, some of which have been going strong for over 10 years, and I’ve not yet laced to the rim on the wheel I’m building at the moment, just considering my options.
(are you making the same incorrect assumption, bencooper?)
aracerFree MemberYeah, but I think I must have flipped it 5 times instead of 3, as it still seems to have the same problem.
aracerFree MemberInterestingly the Open Pro diagram emphasises the angle of the hole where as for the Open sport and A119 there’s an almost imperceptible cant to the eyelet grommet.
Thanks for the research and congratulations on managing to navigate the Mavic website. I don’t think there’s a real difference between Open Pro and Open Sport (I’ve got wheels I’ve built with both), just that the difference is more obvious with the double eyelet in the pro.
I guess I am slightly concerned about losing strength, as I’ll have about twice the load on this as on a normal wheel.
bencooperFree MemberI explained in my OP the reason for wanting to do this – it enables me to have the valve hole in the normal place.
I’m not quite sure what you mean by “the normal place” – usually the valve hole has spokes angling away from it, and the direction of the holes on the rim won’t affect this.
joemarshallFree MemberThis might be obvious to people less stupid than me, but the countersinking is not for the spoke heads, it is for the spoke bend, ie. the head of the spoke should go into the hub on the side opposite to the countersinking. Not knowing that can lead people to thinking that their hub and rim don’t match. See on here:
http://www.troubleshooters.com/bicycles/wheelbuilding/
Also, I rode a couple of unicycles with terribly built wheels (one built by Dave Mariner, with the wrong length spokes (way too long), one Pashley with rubbish spokes and built a bit loose). They lasted for years before self-destructing. So I suspect using the wrong lacing will be fine. Having said that, I never really got on with a narrow rim on a unicycle, even for road. Massively preferred a wide rim.
aracerFree MemberThis might be obvious to people less stupid than me, but the countersinking is not for the spoke heads, it is for the spoke bend
Yep, I’ve got them that way round, but I don’t think it’s at all obvious – though I don’t think it would make any difference if I had all the spokes the wrong way round. The wheel actually had the elbows in the countersunk side on one flange and the heads in the countersunk holes on the other flange when I got it! Thanks very much for that link, it confirms a lot of my thinking.
The original build of this wheel was rubbish – apart from having the spokes the wrong way in one flange, the spokes were also far too long (I think they calculated for 32 spokes which seems to be the default with spoke calculators, as they’re exactly the right length for that – unfortunately the hub is 36 hole). That resulted in very low tension – the last time I rode it a couple of the spokes went completely slack which really didn’t help much with the handling. I’m not convinced a wide rim makes that much difference with a road tyre at fairly high pressure – I have one 29er with a wide rim, and this one with a narrow one (it came with a 729, which is the same width as the A119) to compare, and they feel pretty similar when I’m using the same gear ratio on both.
By “normal place” I mean with all the spokes angling away as you mention. See the “boxing the valve” section in joe’s link – if I build the wheel the way I want to in all other respects I have no choice but for the valve to be in one of the positions labelled “wrong”. There’s a bit of discussion of my issue in the “Symmetric and Asymmetric Wheels” section of that link. They suggest there that if you can’t get everything the correct way you should build asymmetric, however IMO that is the worst compromise in this case as it means the rim will move laterally under power/braking (unlike a bike hub I’d expect equal torque transmission on both sides). Hence I’m left with the choice of either not boxing the valve or not conforming to the rim polarity.
As mentioned above the original wheel build was rubbish – it was also asymmetric and didn’t box the valve, hence I already know that having the valve in the wrong place in the spoke pattern isn’t that big a deal. AFAIK from earlier conversations you own one of these hubs, ben – I think I’ve given enough hints by now for you to have worked it out – I’m curious how your wheel build on one is.
orangeboyFree MemberThinks I must return to this thread when I’ve not been on the malt
joemarshallFree MemberIf the pump will fit on still, I’d shift the rim round one hole and not box the valve in if that works okay. I’d be paranoid about anything other than perfect lacing of the wheel, so as to avoid the flange snapping at the spoke hole that at some people have had on schlumpfs.
aracerFree MemberI think you’re right joe – I’ve just had a look at my other 29er and there is plenty of room to get the pump on in the wrong gap between the spokes – not to mention that this wheel has always been that way and it’s never really bothered me apart from aesthetically. That has to be the least worst thing to do as it makes no difference when riding, and I do want to make the wheel the best I can for that as it’s under quite a lot of stress and goes quite fast for a uni.
BTW I’ve read that link again, and it’s a truly excellent wheelbiulding guide – bookmarked.
Thanks for all the help folks, even if I have eventually decided it’s a silly idea.
adamefFree MemberIf it causes the nipples to point out of the rim at the wrong angle then yes, it does matter. I had a wheel that did this and had three spokes fail at the nipple within a few weeks. Spokes failing at the nipple under normal circumstances from stress is very rare. They usually fail at the shoulder. I re-laced it correctly and it’s been fine since. It does depend on the rim though. Some have the holes for the nipples drilled straight through and some at a slight angle (this is a different thing to the offset and sometimes in addition) to direct them towards the side of the hub that they are meant to join to. It’s more important to get it right with the ones with the holes drilled at a slight angle. If you lace it to the opposite side from the one intended then there is stress in the (slight) bend at the point the spoke leaves the nipple.
The topic ‘Wheelbuilders help – does it really matter if I lace to the "wrong" rim eyelets?’ is closed to new replies.
