Viewing 7 posts - 1 through 7 (of 7 total)
  • Wheel rebuild – OK to re-use spokes?
  • mrh86
    I ruined the rim from my rear wheel and have just got hold of a replcaement rim. Am i ok to use the spokes from the old wheel build or should I get new spokes? (both rims are dt 4.2ds)
    Onzadog
    if they're quality spokes with no visible damage and yo trusted the original build, it should be okay.
    cp
    i've re-used spokes in the past and built perfectly fine wheels. It's more faff though.
    And… you may find it a PITA to undo the nipples on the current wheel – if they're old/well used wheels, the nipples may be seized onto the spoke… solution – cut the spoke…
    ajantom
    I've re-used spokes many times with no problems. If the nipples have seized a bit of WD-40 or similar normally gets them moving.
    If you are replacing a like for like rim, then the best way is to place the new rim next to the old one, wrap some tape around them at 3 or 4 points, then just transfer over the nipples and spokes one by one to the new rim – saves having to lace the spokes or anything. Easy 😀 just down to tensioning then.
    mrh86
    Cheers guys. Well I decided to reuse them. Wheel now laced but I think it may go to the LBS for tensioning and truing (plus for them to check my lacing 🙂 )
    Onzadog
    have a go yourself. If you're not too sure, get the wheelpro book. Last set of wheels I had shop built, I checked with a park guage. Drive side tension varied from 17 to 23! When I did it myself, it ranged from 23-24
    Guess which one will remain true the longest.
    clubber
    Ditto – do it yourself – it's easy really – just use (for example) the Sheldon Brown guide
    http://www.sheldonbrown.com/wheelbuild.html
The topic ‘Wheel rebuild – OK to re-use spokes?’ is closed to new replies.
