As above, I’m aware that spoke tension, especially on the rear will be lower on the NDS due to the dish of the wheel, but it’s more about the feel than he numbers. This isn’t my first wheel build, but is the first where I’ve run into this problem.
Again, it’s the coupling of a lightweight rim (crest 29er) with thin, lightweight spokes (DT Revs) that’s causing the issue.
The spokes are 292mm in length for both sides. The recommended length, (according to my home made excel table) for CK ISO disk hubs on Crest 29er rims using a 3 cross lacing pattern are :
NDS rear = 293.4
DS rear = 292.4
NDS front = 292.4
DS front = 293.1
So 292mm spokes were used all round.
