Nilglass (get it from Lakeland or, now, B&Q as well). I suspect it’s little more than a vinegar solution, but spray on, then use a freshly laundered microfibre (no conditioner) to rub it in, then use a second dry microfibre and rub until it dries to a squeak. Fantastic result but it’s hard to manouvre your arm to rub it comfortably on the front windscreen without pulling a muscle. I’ve never used the Autoglym product, so no idea whether that’s easier, although the results with Nilglass could’t be better IMO.
If you’re ultra pernickety, I’m told that paper contains silica and can leave tiny scratches and swirls over time, which can pick up light and contribute to subtle hazing at night, if you do it a lot (one of the reasons you shouldn’t clean spectacles with tissue apparently). I’ve no idea whether this is true or not but suspect that the scratches on the outer surface would render any internal scratches irrelevant?
