I weighed my Liteville on the bathroom scales with me holding it and then subtracted the weight of Chickenman without the bike; got to be pretty accurate, no?
haha just done the same, me – the bike = 13.8kgs – 30lbs. Could drop a few kgs with lighter rims, forks and the cranks weigh a ton, but she’s surprisingly nimble and you don’t even notice that weight.
Specialized Enduro 2014 expert Carbon 29er. As stock was 28.6 lbs on the park tool scales at work. Just put a fatbar carbon on and converting to tubeless today so should be even lighter.
Freshly alped- coil lyriks, metal wheels, UST highrollers, lockon grips because the ESIs are a bit too easy to destroy, added a chain device which it probably doesn’t need but would be a pain in the arse to find out it does. Oh and swapped my steel axled nanos on because why not. 31.75lbs on the +7 Scales Of Possible Optimism. Wish I still had my Van RC for it but the RP23’ll do.
Though it dawns on me that I weighed a package with them a while back and it came up pretty much identical on the post office scales, so they can’t be far off.
What tyres/forks? You should be miles lighter than me with that lot.
That aise – how are the E13 risms? Heard mixed reports, looked at a set of the LG1s for my DH bike.
Pikes and Schwalbe Magic Mary/HD both in snakeskin 2.35″. Both tubeless.
The TRS rims arn’t bad, although I did crack the rear one racing the EWS in Whistler. It survived the rest of the holiday though, including a tonne of park laps.
The LG1 rims are a bit dent-tastic I think, there are probably better choices out there?
Yeah – just liked the look of the LG1s as much as anything.
As for weights – my Ion 16 is 29.94 lbs on a new set of Feedback bike scales – and other than having 27.5 wheels amd the debonair being slightly heavier, I can’t work out how your bike could be almost the same – either your scales is being unfair to you, or mine are being generous – I’d have expected your frame to be two pounds lighter than mine
I’m building a 2014 Orange Alpine 26″ at the moment with pikes, monarch rc3 debonair, zee cranks and mech, saint flats, 780 renthal bars and stem, formula the ones with 203mm hope floating rotors flows on hope pro2 evo and specialized tyres, charge scoop and specialized command post dropper and by my adding up of parts I reckon it’ll be about 32-33lbs. I’ve had a lightweight ish bike before and kept breaking it so I’d rather have a slightly heavier bike that doesn’t break.
Don’t know if it is really enduro, but Pyga oneten 29’er, Arch on Hope, tubeless Nic / RR, XT double groupset, Hope M 4’s 203/ 180 mm, reverb, XT trail pedals, thomson stem, Kinesis carbon bar is 30.2 lbs on Park Tool scales
Alpine 160 – CCDB and coil Rc2 up front too.
35lbs.
Blech 😉
Never had so much fun in my life as pointing it down EWS8 and engaging gravity.
Oh what fun ….
I was a bit concerned that my 3 quid ebay luggage scales might be a bit flaky but i weighed my 5kg kettle bell and it came out at 4.99 kg which I’ll take
Some of these weights seem perfectly fine to me to be honest.
The difference in weights of tyre is huge.
Put a SG Magic Mary on a 650b … 1100g, put a lightweight tubeless Schwalbe on and you might be half that. That a 1lb per tyre.
Then use a fixed seatpost instead of heavy dropper, light’ish wheels and you would easily see 3lbs or more dropping off a bike, going from into the 30’s back to the 20’s.
So in short, with the right kit for what you want it’s do’able without going carbon mental I think.
2001 (I think) Turner Rfx
Fox vanilla RC coil
Marz 66sl
X fusion Hilo dropper
Charge spoon ti saddle
D521 rims on hope bulbs (from the nineties).
Zee brakes on old hope 205 and 185 5 bolt rotors
Zee mech+shifter
Slx cranks + bash+Superstar thick thin chainring
Saint pedals+bb
Xt cassette
Smorgasbord and chunky monkey folding tyres
Nukeproof bars
Ragley stem
36lbs according to a set of fishing scales. It climbs very well but is a bit nose heavy.
@honourablegeorge. the Newmad in carbon starts at 2.5kg weight exl shock according to manufacturer. The Ion16 in a M is 3.1 excluding shock weighed by anal individuals. My FG Ion at 675mm TT is 3.4kg with steel hardware (cable guides, boltthru axle, shock mounts excl. shock
Like for like stiffness frames Carbon is typically 25% lighter give or take so smidge over 1lb give or take. Much more weight to be saved in careful or expensive component choices than frames.
13.6kg which is around 29.9lb, I’m not in the weight saving game it just happens to be the set up I chose.
cannondale prophet,
Revelation dual air 15mm maxed 150mm travel
Pro 2’s on xm 321
Heavy duty tubes and single ply advantage tyres
Race face evolve xc stem and cranks 2×9 set up with bash XT mechs and shifters
Thompson seat post spoon saddle and rich wrc bars, Hayes 9 brakes and shamans m520 pedals the cassette chain and rings are all cheep deore atm.
I recon I could nock a lb off if I really wanted to but I’m not to fussed
31kg including bag, packaging, spares, tools, knee and elbow pads, 1kg of haribos, and 2 loaves of gluten free bread. I mean, nothing at all apart from the bike
Was intrigued by this thread and about to build a new bike, so checked the calibration on our kitchen scales with a litre of water (pretty much spot on 1kg) and weighed EVERY component as I built.
Orange Alpine 160 26 (Small) with a reasonably ‘enduro’ build (Slants, Flow EX on Superstar Tesla, Butcher/The Captain, XT brakes, SRAM X9 1×10 with a TRex and XT cranks, Superstar Slider chain device).
Spreadsheet tells me 13.6kg / 29.9lb.
Average overall wieght on my archery scales over 5 weighings comes in around 31lb.
Was expecting 32lb or so, so am happy with that (and happy as I can be that a weight of 30.5lb give or take 1/2lb is real world accurate.
Maybe I’ll weigh it again, my cheap luggage scales might be short changing me 🙂
It doesn’t seem too out of range though, there are other bikes of similar spec that are similar weight? FWIW a few people have weighed the frame, they come out at 5.3lbs minus shock.
I still think I could build mine to ~27lbs if I threw a chunk of money at it, but I might start to jeopardise it’s use with borderline inappropriate bits on it, and it doesn’t make me go any faster anyway!
Cheers Glasgowdan, even my xc bikes start light then end up heavy as stuff dies. Either way a heavy bike can ride like a light bike if the design is right and damping is set well, in fact the Turner rides lighter than my hard tail but is physically heavier. The weight is only noticeable on short sharp climbs.
well, random update the wifes away so thought id check and see where I was at after going from the stock sram 1×10 to shimano and oneup and some onone carbon bars, by my maths shouldve had me down to 14kg exactly
hmmmm maybe if I clean it a bit better I can loose 80g
