Viewing 21 posts - 1 through 21 (of 21 total)
  • whats this cog all about ( E bike content )
  • trout
    was looking around a not too local bike shop today and wondered what this
    little cog is all about ( Pros and Cons )
    nickjb
    It’s wrapped around the pivot point so there should be no chain growth as the suspension moves. Should keep it more supple all the time. Some normal bikes utilise this chain growth to stiffen things up so it tightens up under power. I suppose this is less useful a feature with a motor to help and you’ll be putting power down all over the place and you don’t want it randomly stiffening
    frogstomp
    Commencal Supreme DH had similar, although they seem to have moved back to a more conventional setup now.
    parkesie
    To achieve a similar effect to having the pivot in-line with the chain ring.
    wiggles
    Nothing that complicated on the ebike. It is just there because the “chainring” is so small the chain wouldn’t clear the chain stay in the highest gears.
    mickmcd
    it wouldnt clear the swingarm
    beaten to it edit
    nickjb
    If it was just to clear the chainstay then it could have been put in a number of places. They also could have shaped the chainstay differently as its a custom frame. It’s very deliberately bang on the pivot so I suspect there is more to it.
    otsdr
    On the topic of “could have shaped the chainstay differently”, why isn’t it a straight line between the rear axle and the pivot?
    trout
    Thanks Nickjb for the explanation sound sense
    is it better or worse or just another way of doing the suss bit .
    V8_shin_print
    To more closely match the other side? Some Specialized Enduro’s had different pivot points on the left and right sides and I could never get my head round it!
    otsdr
    The other side is wrong in the same way, and it can’t be just for the sake of rear brake routing, they have a massive loop of cable hanging underneath the BB.
    gofasterstripes
    It could be structural, either:
    A – avoiding a long straight stay which may be quite weak
    B – avoiding a sharp curve close to the pivot
    MrPottatoHead
    I’d say it’s creating a virtual chainring size. It’s a very small sprocket on the cranks – looks like an 18-tooth. The extra cog takes it back to being the same as a 32T….maybe.
    BigJohn
    I remember when there was a lot of discussion about pedalling-induced bob. Maybe it’s there to stop that, with the chainring being so small.
    andyl
    Are you thinking it changes the gearing? It has absolutely no affect on the gearing.
    But with that size chainring it must spin out at about 10mph! The chainwrap is also tiny.
    Is there some kind of internal gearing? https://www.bosch-ebike.com/en/ebike-systems/performance-line-cx/
    wiggles
    It is geared inside so the chainring goes round more than once for every time the cranks go round.
    You lot are all over thinking this, it is just to get the chain to stop rubbing on the chain stay… Used by a few manufacturers who use the Bosch motors with tiny chainrings.
    andyl
    ^ was just looking to see that. So the crank is not coupled directly to the chainring and spins faster than the crank? weird.
    MrPottatoHead
    Doesn’t help with the answer but interesting website regardless for demonstrating that it doesn’t affect the gear ratio.
    Gear Sketch
    thepodge
    The new Commencal still has a chain idler.
    Shaped chainstays are for tyre and chairing clearance
    wallop
    OP – you need the snipping tool in your life (it literally changed mine!) 😆
    richmars
    It’s probably on the pivot point to use the same mounting point, so cheaper.
The topic ‘whats this cog all about ( E bike content )’ is closed to new replies.
