Seeing as it is since the shop I would run it back to them and ask them find it for you.
That might not be a bad idea TBH, I'm back there at the weekend for a warranty job on the OH's bike.
Try threads on chainring bolt and pedals – greased and tight.
Aha, pedals. The pedals that I replaced a while back. Good point, well made.
Yes they are but they do not last for ever and will last even less if you keep jet washing and hosing them down.
… ah. Are they user-servicable, or is it a case of "buy new ones and be more careful"?
How overdue was it for the free service?
Bought just after easter, so quite a while; didn't use the bikes for a bit when they were new due to injury and there didn't seem to be much point in returning virgin bikes, then after that it just slipped my mind. I've done about 200 miles on it.
…and that your shoe doesn't rub the crank when you're giving it the berries
Definitely not the shoes, wrong kind of noise apart from anything else. It sounds like the front disc brake, I'm still not wholly convinced that it isn't other than I can't come up with a train of logic that would explain that.
