Have any of you quoting all the issues tried one?
I have one and don’t recognises many of them
ISCG needed yes
Heavy, to an extent, but not particularly so when considering its aimed at a double+bash+chain guides set up and the advantages over a similarly robust setup are there, its like saying dropper seat posts are heavy, 500g on a bike designed for AM use is nothing.
It is indeed expensive but shouldn’t break and provides loads of clearance so less change of rock strikes.
I cant say it feels like there is much resistance in mine, certainly no more than when using a chain guide setup. But frankly I cant tell between it and my normal setup.
I had the problem that doesn’t exist quite a lot this year in the alps, and wish I had it then.
I don’t have any axe to grind as it was on the bike when I bought it, I didn’t choose it, but having used it objectively I think it is great for its intended market and use, not for everything.
