nuke – your rite it is the lower mount, it's not the paint that has gone, what he's done is use a washer to super glue the mount back onto the frame, I new the paint wasn't perfect, but you cant see how bad the paint is from the ebay pictures. Its shocking, just as well I always planed to re-paint it or I would be sending it back quick smart, your correct that he has put up some good photo's and you can clearly see the washer, it's funny Cu's I browsed through the photo's a good few time and never noticed it.
Quinn- I know exactly what you mean regarding the geometry, this is what I'm trying to work out, I suspect that its a 2006 i have, in which case does this mean it will be OK with 130mm travel forks??
Does any one have a pic of the older frame, before they changed the geometry to take 130mm forks ???
