A good while back I bought a Solitude Cycles frame off of here for peanuts.
It was in pretty poor condition needing new paint and as it was originally built for a Rohloff didn’t have gear routing or dropouts (Paragon) capable of running gears.
Despite being designed for 26″ wheels the frame has oodles of clearance – it will take my 29+ rear wheel.
From the off I really liked the frame.
Over summer I bought some geared dropouts, new adjusters and mounting hardware.
Then recently a local frame builder added some guides, filled a dent and added a HT scuff plate to match the one on the other side.
Sweet.
Dropped the frame off at my local, excellent, powdercoaters and told them to take it easy on the blasting as the Columbus tubing is pretty thin.
Picked the frame up today in glorious RAL6019 to find a pin hole in the ST and the seatstay brace peppered with holes 🙁
There are also a couple of areas under the paint that concern me.
Frame builder has had a look and given a very reasonable price to fix things but at the cost of my paint.
So …… Continue down the path of repair, just ride it see what happens and repair or wall hang.
The money is in the equation but the worry that’s grabbing at me is that all the tubes are sealed, no breather holes with the exception of bottle cage bosses and rack mounts. Having seen some of the 90s American exotica die from a combination of sealed tubes and our weather I worry I would be throwing good money after bad.
Frame builder thought the frame was structurally sound to ride and suggested butting a sticker over the pin holes but I told him stickers were resolved for cracks 😆
So ….. If you got this far reading the post congratulations ….. But what would you do?
