How many people really experiment with their pressures? I know I probably should but I’m not keen on being stuck with a flat somewhere because I went and ran a tyre at 8psi so I tend to stay in the same 10 psi range…
I’ve run as high as 45 before and still found it ridable but now tend to go between 25 and 35 depending on type of riding I plan to do and the tires I’m using… 2.3 Eskars or 2.1 Captains both run tubeless, although I just got some 2.0 Michelin XCR tubeless to try out next summer (cheap on CRC) may play with the pressure in those a bit just to see…
I’m 5’10” and weigh 12 stone, is there a proper formula? for weight/tire/pressure settings?
