Needed to get the bearings in my front hub replaced before this weekend on my Bontrager Race Disc wheel – went to do it myself only to realise I didn’t have the right tool to get the bearings out. Took it to LBS for them to do the job and got right royally fleeced for it (if you’re a Derby local you can guess which LBS it was).
Anyway, I need some sort of 4 pronged tool to undo a lock ring which tightens up against the bearing on one side of the hub. Searched a few online shops but can’t find anything – closest I can find is a Hope tool for older hubs,
Anyone got a clue what tool I need? (Having said that, next time the bearings go I think I’ll be replacing the hub for a Pro II and never have to bother with servicing again!)
It’s a miniature C-spanner, and should have come with the bike(but nobody knows what it’s for until they have to strip the hub, so you may not have received it), give Trek-UK a call and they may well send you one.Bearings are run of the mill 6001 if I remember correctly, but will wear quickly if not fitted correctly as the axle has no stops/spacer to prevent them being overtightened/preloaded.
Hijack >>>Top tips gents, i was wondering what that funny little “C Spanner” was for that came with my bike. i’ve even had to take my Bontrager rythm comp wheel back to the shop i bought it from to have the bearings sorted out. They did it free last time but it needed doing again. Took me 10 mins tonight with the c Spanner.Thanks guys!!
Posted 15 years ago
Viewing 9 posts - 1 through 9 (of 9 total)
The topic ‘What tool to remove bearings from a Bontrager Hub?’ is closed to new replies.
