Viewing 40 posts - 1 through 40 (of 40 total)
  • What to do with Polenta?
  • mattsccm
    Got a slab in the cupboard and can’t think how to make it yummy. Simple ideas please.
    Covering it in gravy is one option but I am sure than the masses here can do better than that.
    beaker
    Google lemon and polenta cake…..
    yourguitarhero
    https://www.williams-sonoma.com/recipe/jalapeno-cheddar-corn-bread.html
    cornmeal/polenta are basically the same thing
    mrmonkfinger
    Replace it with chips.
    And cover them with gravy.
    Cougar
    Nigella’s.
    (Though, that uses the granular stuff rather than a ‘block’)
    mossimus
    In the village my FIL comes from they spread polenta on a suitably covered table and then top with bolognaise.
    nickc
    is the correct answer
    perchypanther
    Use it to weigh down the menu for the Chinese Takeaway.
    jamesfts
    DIY?
    Pretty much the only thing polenta is good for is a building material.
    mattsccm
    Valid point about the chips.
    Could I use it to ghetto tubeless my tyres?
    Jakester
    I once bought that pre-made slab polenta.
    I think you’re supposed to fry it.
    Still tasted rank.
    I’d bin it.
    Missus made Nigella’s polenta, lemon and raspberry cake yesterday – highly recommended (but as pointed out, uses loose polenta, not cooked).
    Otherwise we sprinkle a bit on potatoes before roasting, and use on pizza bases to stop them sticking. Once tried making cooked polenta from the meal – it involves about an hour of constant stirring, and the end result is rank.
    mrmonkfinger
    Probably, it’s quite slimey.
    thisisnotaspoon
    Dunno if that’s a quirk of the pre-made stuff, but proper polenta chips are epic.
    Can also make polenta ‘roast potatoes’ same idea, just make it a ball and shallow fry/roast in the oven like you would potatoes.
    Add water, stir until smooth, leave to set, done.
    Ecky-Thump
    Boil it; then throw the water away.
    Boil it again; then throw the water away.
    Boil it again; then throw the POLENTA away and use the water for a pot noodle instead.
    Nobeerinthefridge
    Binners to the forum.
    Binners loves polenta….
    yourguitarhero
    Polenta fries with garlic and rosemary, mmmmm
    somafunk
    Polenta?….. it’s just a poor mans sugro
    n0b0dy0ftheg0at
    Going slightly off-topic, but yesterday I discovered Co-Op’s Cheddar and jalapeno loaf outside of the New Forest for the first time since our camping hol three years ago… Amazing (despite I’m sure it’s shrunk in size due to weak pound)!
    RamseyNeil
    In my cheffing days we used to slice it thinly and use it instead of the pasta in a vegetarian lasagne .
    Cougar
    Proper gave me the giggles, thanks for that.
    slowster
    Brush slices with olive oil and grill on both sides till crisp and brown (~3 mins), then serve with
    – prosciutto
    – asparagus and shaved parmesan
    – fresh red chilli and rocket
    – anchovy, rosemary, lemon and olive oil dressing
    (From The River Cafe Cookbook)
    Top with slices of Taleggio cheese, and grill so that the cheese melts.
    (From Made in Italy by Giorgio Locatelli)
    dannyh
    Use it to stand on to reach anything else in the cupboard.
    If you only find tofu, kill yourself.
    allan23
    Cut into slices, drop down toilet, flush and cut out the middle man. The only thing with less taste and worse texture is SiS Gels or wallpaper paste.
    gavinpearce
    Bin it.
    johnx2
    can be used as a stand in for mashed potato. Depends on the kind of party…[video]https://youtu.be/qjE6qrYyE6Q[/video]
    thisisnotaspoon
    Philistine’s the lot of you!
    How can you say it has no flavor when:
    a) it probably has more flavour than the majority of carb’s
    b) it’s not supposed to have flavour, you’re supposed to flavour it. That’s like decrying Italian cooking because Pizza is just unleavened bread and pasta is a bit bland!
    Well, two are corn starch, and the other’s probably partially inverted corn syrup.
    Russell96
    Was quickly scanning the forum post titles and for a moment I thought it was Placenta. You do not want to Google the cooking tips for that!
    poly
    If we are talking about polenta already made on a block then slice about 10mm thick, season and oil and fry on a hot griddle pan (so you get nice scorch lines on it). Make a thick sauce (e.g. strong flavoured tomatoey sauce). Cook some meat (perhaps chicken roasted in the oven with some herbs and lemon. Fry some pancetta (or thin bacon) until crispy.
    Put polenta on plate, add sauce around the outside, put pancetta on top, add chicken.
    If you want a recipe there is something like this is one of the Jamie Oliver quick books (I think its in his 15 minutes – which means it will take normal people about 40!).
    If its not the solid block type polenta, then work out how to transform it – because like mashed potato, once you’ve had roasted or chips mash is just not going to win!
    nostoc
    I beg to differ. Cook polenta soft and porridgey(?)on day one, fry/roast it on day two. (I think you underestimate mashed potato also).
    But, sure, it is always going to be bland carbs. Just add enough olive oil/butter, fresh herbs, salt and pepper and serve it with something with sufficient guts that it needs some bland carbs
    dangeourbrain
    Russell96 – Member
    Having eaten polenta I’m trying to decide which sounds less appealing.
    simondbarnes
    I was going to say throw it away and buy some chips but it appears that I’ve been beaten to it.
    mattsccm
    Well the instructions ( the quickest and easiest of several on the packet) said fry until crisp in olive oil. Bugger that, I’m no hippy so I used bacon fat. Actually tasted alright. Filled a hole. Not rushing past a chippy to buy some more!
    funkynick
    Having just been given a 25kg sack of the loose stuff I’m following this thread with interest…
    I fear it might take a while to get through!
    dpfr
    Ah! If you’ve got the dried stuff, then orange polenta cake is yummy. 25 kg would let you make 180 cakes
    funkynick
    Only 180?
    So that’s only one cake every two days for a year… what could possibly go wrong with that? 😀
    poly
    funkynik – as well as the cakes… you can turn it into other forms, including “bricks” to make into slices/chips, or use it as a “crumb” on the outside of other stuff.
    nostoc- I beg to differ. Cook polenta soft and porridgey(?)on day one, fry/roast it on day two. (I think you underestimate mashed potato also).
    I am certainly quite particular about my mash, and nothing disappoints quite like naff mash, well except porridge, and polenta mush! BUT I can appreciate a really good mash, so I expect I could appreciate a good polenta mush. I doubt I will ever appreciate porridge.
    mattsccm – I’m no hippy so I used bacon fat. Actually tasted alright.
    of course, everything tastes better with bacon.
    thecaptain
    I use the dried stuff for cornbread.
    Nobeerinthefridge
    Had polenta with a wild boar stew in Italy, the hotel riviera bikes use, it was awesome.
    tuskaloosa
    We were at Veneta last night Veneta and they served Polenta Croquettes with a sliver of Proscuitto in between the the croquette… sublime
    muttley109
    Simmer a ham hock with stock veg, bay leaves, parsley stalks and thyme for 3 hours.
    Remove the skin and place in a roasting tray, put the ham hock on top and coat in a mixture of soft brown sugar and mustard. Chuck a handful of sage leaves on top. Roast for 25 min.
    Strain the remaining ham stock and pour into a large pan. Add polenta whilst continuously stirring. When smooth, leave to cook for 5-10 minutes. Then add grated, strong cheddar, chopped parsley and butter. Mix well and season.
    Remove ham from the oven and shred.
    Splodge polenta onto a plate, top with a handful of shredded ham, a few crispy sage leaves and a serve with a dollop of mustard.
    Polenta doesn’t have to be bland, you just need to cook properly!
The topic ‘What to do with Polenta?’ is closed to new replies.
