I would fit six, I guess, as you can’t step down in size from a bit outlet to a smaller liner, but you can go up, although it may compromise the performance of some stoves.
Are you sure you can’t take a look around and choose a stove now, even if you don’t need to make the purchase?
At the same time, take a look at Part J of the building regs – you may need additional ventilation and there are specific hearth materials/dimensions to note.
Presumably, you’re getting building regs approval for the chimney work – if you get the burner sorted completely now, you may be able to get both signed off without putting in an additional building notice, saving a little bit of cash.
If you get it sorted now, you’ll be toasty this winter…
Oh, and you also need to specify the grade of liner depending on whether it’s definitely logs only or multifuel.
