Similarly intrigued as to how a frame that has been replaced under warrantee found its way back onto the market.
EDIT
andysredmini – Member
I bought it from a local classifieds. I checked the serial No. against the stolen bike register online before I bought it and gave it a good check over but obviously not good enough.
I do wonder how it got back on the market.
Giant would presumably have an idea – they’ll know who presented the original warrantee claim. You could at least ask them what their procedure is when warrantee replacements happen and whats supposed to happen to the replaced frame
I guess you have look at the position of the crack and consider how awful the consequences would be if if gave out totally. If the result would result in you having to carry your bike home thats one thing, you having to scrape your face back up off the floor and carry it home thats another.
A weld without heat treating might not be a better solution than just having a crack there – the weld might not be any less likely to give up than the crack is.
There are other strategies you could try – find the end of the crack and drill a little hole there – its should stop the crack travelling any further (and also gives you a datum point so you can see if it is travelling).
The other is I’ve seen people bandage up the seat/toptube junction with fibre glass / carbon fibre – so that if the frame does fail theres at least something holding everything approximately in place.
