Ooh – they do a deeper rim R501….. not that I need it, just looks nice!
AVOID!!!
The 30mm rim is about 100g per rim heavier than the 24mm version, and adds no benefit whatsoever. Standard R500’s aren’t actually that heavy for what they are, but the 30mm version are.
R500’s are a solid wheelset. They’re easily serviceable, spare parts are readily available, they roll well, they’re strong and stiff etc. The only real negative is that they’re not the best sealed hubs around, so an extra squirt of grease in the bearings from new, and a planned maintenance routine is required to keep them in tip top condition. But then again at under £80 a set if you get a year out of them they’re still a bargain…
FWIW RS11’s have marginally better hubs and are a tiny bit lighter too, so may be worth it if they’re only
a few quid more, but don’t get too carried away if they’re mostly for commuting.
