I do a mix of on and off-road riding, but mainly on road (country roads etc.). I'm currently using Panaracer Razer XC tyres and, despite initial worries that the extremely widely spaced knobs would make things dicey on tarmac they've actually turned out to be great, much better than the conventional semi-slicks I was using (the knobs are very shallow which probably makes a difference).
I've not really ridden them on wet tarmac before today but started to notice when braking that the rear wheel seemed to skid more easily than in the dry (I generally brake with both levers equally). Now this could have been part psychological, I'm sure someone on here mentioned that they hadn't liked their Razers on wet tarmac, so I may have been a bit nervous to start with. What I did notice however was that I had no skidding with the front wheel which has a bigger rotor and is less weighted than the rear and I would assume therefore more likely to slip in the wet.
Anyway, my questions, am I imagining/over-playing things or are the Razers not a good tyre for wet tarmac and what actually makes a tyre grippy on wet tarmac, is it the tread pattern, tyre compound or a mixture of both?
