Viewing 9 posts - 1 through 9 (of 9 total)
  • what light is like a joystick but not a joystick…..
  • trail_rat
    Mrs t-r needs new lights.
    shes joined a 4 for the puffer
    Shes borrowed my joystick and wants a helmet light with no cables like that.
    I want the bracket to be a joystick bracket so she can use my joy stick easy when she wants…..
    What options do i have ?.
    (anyone got a second hand joystick forsale 😉 )
    Trimix
    A joystick then.
    trail_rat
    none of the DX torches or the ilk will fit a joystick bracket ?
    coastkid
    This one 🙂
    Ultrafire p10-R5 by coastkid71, on Flickr
    Ultrafire p10-R5 350 lumens by coastkid71, on Flickr
    RustyMac
    Terry,
    I have a Mk1 or Mk2 diablo that she can borrow for the puffer if that is any use?
    [edit] Exposure mount is 23mm diamiter, most of the DX ebay jobs are 25mm and a very very tight fit as they use removable batteries[/edit]
    [edit2] that one in the pic looks a good option [/edit2]
    trail_rat
    Bruce – whats one of them cost all in once you add a batterys and charger ?
    Northwind
    As per CK… Torch of your choice. I helmet mount mine with an old Joystick mount (needed a few wraps of electric tape to bulk it out), works enormously better than the best Joystick tbh (though a bit bulkier).
    I use an XML torch because it’s for road use, but for offroad I guess I’d go back to my old P7 torch instead. Total spend on either was about £20 including spare batteries a cheap nasty charger- doing it again, I’d spend a bit more on the charger.
    (I rant a bit about this, but it’s not so much that the Joystick is just a torch- though, it is. It’s that it’s a torch, with one of the best features of torches removed- no easily replaced battery. So you spend a lot extra for a downgrade)
    coastkid
    Total was i think £26 for torch (£14!) charger and two batteries,
    not had a meltdown yet with the charger! 🙂
    Joystick helmet mount was £17
    A great wee light and has been reliable 🙂
    london_lady
The topic ‘what light is like a joystick but not a joystick…..’ is closed to new replies.
