Just be aware that riding a completely rigid bike around a trail centre for a day takes some serious willpower, even for a grown-up and it’s a really big ask for a kid. I see a few people here making comments about “kids not needing suspension” and “it’s all weight” before jumping on their own enduro bikes to go out riding with them.
My son transitioned from a 20″ rigid (Beinn 20) to a 24″ hardtail (Creig 24) to a 26″ full-suss (Frankenbike!) and this worked brilliantly for him, allowing him to hone his skills while doing longer and longer rides. Yesterday we did a local endurance event and he was pounding down stuff quicker than his dad could keep up – I’m certain he couldn’t have completed this course on a rigid bike, at least not without a lot more time and a boat load more complaining!
Anyway, now that’s said, his current bike is a 27.5″ frame with 26″ wheels. It has a 27.5″ fork (Fox 32 Factory) but travel-reduced from 120mm to 80mm and this is absolutely the best fork I could put on this bike even if money was no object. As an alternative to a rigid fork, perhaps you could do the same by picking up a good quality 26″ fork and then reduce the travel and fitting it with 24″ wheels. If you do this, you’ll be in illustrious company as it’s what Islabike do with the Creig 24 Pro because you can’t really buy decent quality 24″ forks, so they use 26″ instead:
http://www.islabikes.co.uk/products/pro-series/item/creig-24-pro-series
You’ll need to watch the geometry too though. I was able to adjust this through offset bushings on the rear shock, but you won’t have this option so would be limited to an offset headset, if your frame will take one.
