The size of the chain ring is irrelevant if you just have the one.
Shimano tech documents give max cog size, min cog size and capacity. The capacity you need is your max cog size minus your min cog size (plus an allowance for suspension action).
Shimano are conservative with this numbers, so when they say min is 11, you might get away with 10. They’ll say 46, you might get away with 48.
The exact geometry of your rear mech hanger will also influence this.
If you want to try 11-50, give it a whirl, if it doesn’t work, fit a oneup shark cage.
Also, make sure you’re chain is long enough. 114 links might be just too short for an 11-50 with a 32 on a full bounce bike.
