Viewing 16 posts - 1 through 16 (of 16 total)
  • What is this?
  • composite
    So for my second potentially embarrassing post today. 🙂 I have received a bunch of deliveries at work this morning for my new build. I have spent most of the morning cooing over bits and packing them away to take home. I then noticed this on the floor. What is it? 😕
    Jamie
    It’s to stop the bolts on your brake calipers coming undone.
    Edit: I should add I have never ever ever ever used one.
    Edit 2: I dedicate this post to somafunk.
    annebr
    part of a clamp that goes around a seat post or handle bar?
    dan86
    they sit on the caliper bolts to stop them working loose!
    EDIT – Jamie beat me to it 😀
    davidtaylforth
    Nice one Jamie, your knowledge of cycling is truly unmatched.
    I never knew what they were for!
    wwaswas
    It’s a pushloc 😉
    thepurist
    It’s to leave in the box that your brakes came in because nobody ever fits them and there aren’t millions of threads saying ‘help my brake caliper bolts have come undone’ so that must tell you something.
    PS – is that carpet, lino or flesh?
    somafunk
    It slips over the brake caliper bolts to (hopefully) prevent them vibrating loose, i’ve never used nor fitted them to any bike, if you are in any way semi-savvy with an allen key and occasionally check your bike over before use then throw it in the bin.
    Damn……you forum peeps post fast.
    bails
    Shimano brakes?
    They go around the brake caliper bolts to stop them rattling loose.
    No idea how necessary they are but that’s what they’re for.
    Edit: Too slow!
    composite
    wwaswas – Member
    It’s a pushloc
    PS – is that carpet or flesh?
    It’s a pick card document folder. I realised how flesh like it looked once I put the pic on the computer and wondered if anyone would comment. 🙂
    MSP
    But there should be three more, and if you have lost them think what other life saving parts you may also have lost in your eagerness to unpack new shiny bike parts.
    This can only end one way, in a huge fireball of death 😉
    somafunk
    pedant alert – Jamies pic shows incorrect fitment, it fits over the bolt head once tightened.
    edit, jamie amended his post…..i give up……. heading out to ride my bike instead.
    Jamie
    Northwind
    It’s genius weight reduction- if they weren’t included, you couldn’t save weight by not fitting them.
    johnners
    Do Shimano brakes still include those bits of wire?
    somafunk
    Was that the tying wire to pass through the drilled bolt heads?, if so then nope.
    Avid brakes come with a length of broom handle to shove in your front wheel to aid you in stopping.
    That may be a lie but Avid brakes are bound to fail at some point so they should consider it at the very least.
The topic ‘What is this?’ is closed to new replies.
