"22+30+38 you could probably get away with having 7 or 8 gears on the back 11-30 this should be plenty for most situations"
22-34T is an extra gear over 22-30T, I use this bottom gear a fair bit on steep(er) hills, either at the end of a longer ride when I'm on my arse, when its really really steep and/or when I want to be able to spin fairly fast (rather than grind away) over the rough
Re: its quicker to walk, spinning quite fast in 22-34T is faster than walking IME, plus I went for a bike ride, not a walk with my bike
Only times I've really really wanted higher than a 32T chainring on FS bike has been on road downs (good bits but still). I'd like a 36T so I'm not using the smallest end of the casette so often and spinny, but I don't really want the 14T jump between 22>36T tbh, I'd be losing 32-34T which is quite useful for up-down-up-down-up-down trails where I'm up and down the casette
"You can get an 11-36 10spd cassette for ~200g if you really want, which is lighter than nearly (or possibly all) 9spd full sized "
Yes, but how much does an XX 10spd 11-36T casette cost?
"you use it downhill the chain has more tension so rattles against the stay less"
I used to do this, I often found I ended up with the chain halfway (or further) up the casette, the chainline then not only was less efficient, it very often pulled the chain off the big chainring over the rough.
I found within 6 months of fitting new outer chainrings (which I stopped using since shimano figured how to make (middle) chainrings that aren't made of cheese (since SLX came out) I'd worn the teeth so badly the chain wouldn't stay on it.
2*9 + medium cage mech + shorter chain suprised me how much less my chain falls from middle to granny ring (And then off and jamming against a frame pivot). Its pretty much never now
Mech hitting chainstay? A Shadow mech gets round that IME
(Or chain slapping chainstay?)
"Bashguard is required to allow the screws to tighten"
Not if you use short ones?
