The dessicant unit are generally better re noise level.
Plus (tho' it's mebbe not so important in a house) they work fine down nr zero degrees, whereas refrigerant units are less efficient (tho' cheaper to buy).
We've got a couple of Ruby Dry (AKA Amber Dry) units in outbuildings at the bottom of the garden where bikes/tools/plants are kept - don't seem to notice much difference on the electricity bill (at least, with one - only just bought the second after having had the other one for 3 or 4 years). Humidity settings are 40/50/60%, 60% seems to stop things rusting, also keeps the place above freezing in winter.
There's also an X-Dry, fewer humidity settings (tho' also a laundry mode) - the Amber/Ruby seems to be recommended for house use 'cos the fan options means it's generally quieter. Other thing with the X-Dry is it's got a timer on it, plus it autostarts if the power goes off. Smaller tank capacity than the Ruby/Amber. All of them you can fit an external drain pipe to.
All the above are about the 199 mark.
(Curiously Dry-It-Out - where I've bought the second from, since they were particularly good at swapping the first when it was DOA at delivery - also sell via ebay, but are more expensive online on their homepage.)
There are other dessicant units of course, but those are the only ones I've looked at since the original's worked well.
And yes, keep doors/windows closed.
