Best what? What spec/detail is most important to you?
Fastest freehub pickup speed, servicable freehub, weight, not cup/cone, least rolling resistance, quiet, loud, able to run singlespeed sprokets (not paying for widebody ones), axle compatibility/type (5mm QR, 10mm bolt up/nutted, 10mm thru QR, 12mm 135/142), ease of axle type changing, colour, logo garishness, warranty, reliability, brand name?
A Superstar Switch Evo is very similar to a hope pro II, same freehub pickup speed (24points/revolution), similar 300gish weight, cartridge bearings, mutliple axle type and ability to take different axles, as loud freewheel noise, if not louder, multiple colour choice
Differences are probably warranty, name, logo garishness and unknown reliability? Not sure if switch evos will take a SS sprocket
for reliability all Ive got to go on is a few threads on here on old pro II (not evo) bodys cracking around spoke holes
Shimano SLX have a 32point pickup speed with traditional/proper cup/cone setup for ~£35. you could put a 10mm solid (threaded) axle with nuts on if you wanted to stiffen up a bit from the 5mm QR
Something like 380g or so though and centre lock only
Shimano XT has a 36point pickup speed with a different cup/cone assembly that Ive read can undo itself more than the normal cup/cone type used on SLX (tighten normal ones up plenty and IME they dont undo). I reckon Id be adding a bit of threadlock ought to cure any issue?
Still ~330/340g, cant remember. around £50
With the odd cup/cone arrangement unless you can CNC/mill something up, you’re stuck with 5mm QR. No option of going 10mm thru bolt/QR
There is a 12mm/142mm thru axle version available but you’d be stuck with that too and I guess will be like the shimano 15/20mm front hubs which need special (££) sized cone spanners to service
Also centrelock only, at least in 5mmQR, not sure
OnOne has (had?) a hub for £40 which comes standard with a 10mm thru bolt QR (they fit in QR frames). It looks as if it must be cartridge bearing. Weight is claimed as 305g. When I asked them what the pickup speed was and how loud it was, they said it was loud, but didnt know what the pickup speed was
Must be more to choose fro out there
