as above is it the 10mm one?
thx
thx
sorry?
9mm quick release
10mm thru axle
12mm maxle iirc.
10mm
Thu axle = 10mm Std on the back and 9mm front - so you want a PRO II hub kit or hub 135 (std) with 10mm conversion kit from hope - did it 3 months ago on my Five.
The 12mm is the maxle version so I think you need the 12mm conversion kit or but as a hub/built wheel. I think - can't get onto CRC to check!
i was looking at a alpine which uses a 9mm maxle... sorry..
you can get a 9mm maxle? I thought they are all 12mm
if it really is 9mm then you don't want to use a Hope 10mm axle, cos it'll move. Not much but enough to cause problems.
But like the others have said 9mm at the back is news to me. Mind you I thought it was 9mm front and back until I checked it out for the Pro II 10mm conversion I did on my rear hub.
And if it's an Orange Alpine, I though that was 12mm - which Orange's spares list seems to suggest is the case (though not conclusive) - and the fact that they are using a Pro II rear hub which comes as QR, 10mm bolt up, 10mm bolt through, or 12mm Maxle again suggests 12mm. Of course they could have spec'ed a bespoke, and therefore more expensive, less strong 9mm axle, but I would be surprised
are you sure its 9mm mate, i know its a different bike but my blood has a 12mm maxle. id of thought it would be the same on the alpine as both bikes are specd in either all mountain or freeride options.
LoL my bad i skimmed a MBR review *embarrassed look*
clearly it's a 12mm not 9mm
Runs
there u go then get a 12mm conversion kit same as i did. dead easy to fit. silly man lol
shurup you tart
your fault i'm looking at getting an alpine.... Heckler all serviced and new pinch bolts fitted, bearings replaced and forks are back from TFTuned, 2sep removed and coil fitted.. lovely n plush now..
recon the alpine with a rp23 2010 with boost plus 160 coil lyrik will be a good setup..
who do you think you're talkin too
how's it my fault what have i done? ahh cool u might keep up with me now lol
yeah sounds good, be ace to compare it with my blood!
your a bike tart...
i know it..
not your fault m8, just jokin about.
i have a demo alpine coming soon, i'll let you know when.
I'm a bike tart?
I know your messin mate.
Awesome nice1
yer all your colour co-ordination
green pedals too to match the frame.
What's wrong with that like? You can pick on me but leave the bike out of it lol.
Alpine is going to be here for the 15th/16th. feel like a Afan visit?
Yeah defo mate, I'll be there. Ali already asked me, just give me a time and I'll be early LOL.
