Viewing 21 posts - 1 through 21 (of 21 total)
  • What headset for Overdrive 2 steerer in On-One tapered frame?
  • mark88
    I’ve ordered a carbon On-One Lurcher which has a “mixer taper head tube” (44mm upper, 49.6mm lower) and plan on using the forks from my old Giant which has Overdrive 2 steerer.
    Is this a compatible combination? and do I have any alternative options to On-One’s Smoothie Mixer headset?
    ratherbeintobago
    Isn’t Overdrive 2 Giant’s odd ‘standard’ with a 1¼” steerer?
    mark88
    Yep, hence my confusion.
    Edit: it’s a 1.5 to 1.25 taper I think
    ratherbeintobago
    Don’t think the Smoothie Mixer will work as the top one is presumably ZS44/28.6 and you need a ZS44/31.8. Only one I can find with the right top cup is the FSA No. 51 but the bottom cup is the wrong size.
    mark88
    http://www.pinkbike.com/news/Giant-OverDrive-2-Steerer-tube-sizing-2011.html
    The impression I got reading articles like this, is that it should be compatible.
    Anyone able to advise any further?
    faustus
    Giant’s overdrive system is horrid. With a 1.1/4″ steerer, won’t that limit your choice of stem to Giant only?
    ratherbeintobago
    Yes and no. The bottom cup from the Smoothie Mixer should be compatible, but as I’ve said above, you’ll need a ZS44/31.8 top cup, and as per that PB article, the only people that seem to make those are FSA.
    OverDrive2 is indeed a horrible ‘standard’; I notice that it’s not taken off in the two-three years PB were suggesting. Do new Giants still come with it?
    bentudder
    You might want to have a look at the options Hope has put together – you can mix and match.
    One other thing: What’s the offset on the Giant forks? You might want to understand what changes that makes to the geometry.
    honourablegeorge
    faustus – Member
    Someone makes an overdrive stem, they had them on Wiggle
    honourablegeorge
    mark88
    I heard that Ritchey do one, but of what is readily available it’s Giant only. I’m swapping the forks and stem from my old Anthem onto an On-One so stem etc isn’t a worry for me, just headset
    mark88
    Hmmm that wasn’t what I wanted to hear!
    It looks like it’s staying for the 2015 range.
    I had a quick look and from my limited understanding it doesn’t look like Hope have anything fit the top.
    Not thought about the offset, is it likely to be different?
    khani
    I think This might fit…
    STATO
    From what i read the top bearing is the same outer diameter but obv larger inner, so you should be able to get a generic Giant top cup and race?
    andyl
    Did a quick google and found this: http://www.mcconveycycles.com/store/product/18622/Giant-Fsa-Overdrive-2-Od2-Mtb-Headset/
    Doesnt state the top bearing sizes but the part number leads to here:
    http://www.thindustries.com.tw/?language=zh_TW&mod=7&class=1&mod_class=0&action=read&item=3
    MR136 has an OD of 41.8mm and an OA of 45deg.
    If the normal on one mixer headset has the same outer bearing dimensions then you should be able to use the bearing and split ring from the giant headset but obviously the top cap may be a problem as it may not fit the on one headset. Superstar and Hope also do headsets that will work in the On One frame.
    If the Giant headset cup is the same OD (44mm) then it would fit.
    edit: just looked up a Trance X on cane Creeks wesbite and it says the top is a 44 and the bottom a 56 which suggests the same zero stack top cup but a different (larger frame bore) zero stack 1.5″ bottom cup.
    So you should be able to us an external 1.5″ lower cup ie an on one mixer, superstar tapered or Hope external along with a Giant OD2 top cup.
    mark88
    Awesome, thanks for the help.
    mark88
    Final question – will the bottom cup Hope Type F 49/40 1.5″ fit? (frame is a 49.6mm lower)
    And if it will, I won’t need to order a separate crown race will I?
    ratherbeintobago
    There’s a Hope Headset fitting chart; this suggests a Type F cup should fit.
    Offset shouldn’t make that much difference as he’s reusing the forks off an old bike which presumably have the appropriate offset for the wheel size. Anyway, how much difference does it really make (he says, using 46mm offset forks on a frame designed for 51mm)?
    bentudder
    Apparently, quite a bit.
    You might find your steering is a bit quicker. It won’t end the world, but I certainly noticed a difference.
    Going on the rigid forks from my Singular Hummingbird back in the day, the offset has a significant (ie noticeable) difference in handling, especially when you’re moving between frames with different head tube angles and lengths, too.
    Aside from the Hummingbird, Gary Fisher ran custom offsets on its G2 bikes – so it’s worth establishing whether Giant has, along with a non-standard steerer diammeter – also tinkered with offset.
    bentudder
    Rather than edit that last comment: Probably worth looking at something written by someone who actually understands it properly (ie, not me) – here’s the Singular Cycles explanation: http://www.singularcycles.com/tech/
    ratherbeintobago
    Having had a look at Giant’s website (promoted by the comments on this post on BR) it looks like they have done away with OD2 – everything seems to be listed as OD, which is conventional 1.5-1? taper.
The topic ‘What headset for Overdrive 2 steerer in On-One tapered frame?’ is closed to new replies.
