Viewing 6 posts - 1 through 6 (of 6 total)
  • What happens if….BB shell question
  • Stoner
    What happens if you try and fit a 70mm square taper BB in a 68mm shell? do the cups just seat down on the BB whilst still having threads proud of the shell (say 1mm on each side) – is that really a problem?
    Blazin-saddles
    No such thing as a 70mm shell, I guess you mean 73mm? you would need to space out the difference, what might be a problem is not having enough thread left going into the frame.
    nickc
    Durrr, Italian, back of the class.
    Dunno, TBH Stoner, suck it and see. Can’t think that it would make a huge difference, you could space it out. I’ve used cassette spacers behind cups before
    Stoner
    aha – Italian’s not going to work with a standard ISO/British thread then is it?
    bloody continentals!
    cheers for the info guys.
    STATO
    i think italian thread bb’s are a different diameter anyway, as well as both left handed? it wont work anyway basically.
    Steve-Austin
    I had a titanium GT Xizang with a 70mm BB. conventional thread.
    I used a 68mm cartridge BB and it worked fine
The topic ‘What happens if….BB shell question’ is closed to new replies.
