Viewing 9 posts - 1 through 9 (of 9 total)
  • what grease for my rear hub
  • carlphillips
    as above im stripping my bulb down on my heckler (its making a funny noise)and the last time i did it someone mentioned a specific grease (i just used finish line teflon white grease last time) what is that green gunk that bike shops use called?
    cheers
    Onzadog
    I don’t know what the green stuff is but I like Silkolene RG2 from the motorbike shop. It’s red!
    matt_outandabout
    I use Shimano grease – thats bright green…
    Dibbs
    The Shimano Dura-Ace (used to be called Pro-set Lube) green is fluorescent green, its the best stuff I’ve found by far.
    retro83
    Second the Silkolene, brilliant grease. Thick, sticky and red. mmmmmmmmm
    TandemJeremy
    Any decent multipurpose grease. I use castrol myself. White grease IIRC is not thd right thing for hubs
    PeterPoddy
    Any thick old gunk will do.
    “Bike specific” greases are a rip-off.
    Personally I ‘borrow’ the odd grease cartridge from work which is Total Multi Complex EP2 if you’re bothered. We use it (By the carton-of-24-load) for lubricating the pivot bushes on heavy plant. Luuuverly’n’sticky!
    :o)
    carlphillips
    cheers all..!!
    Dibbs
    I have access to loads of EP2 etc. at work, but its nowhere near as water resistant as the Shimano grease which has a higher Silicon content.
The topic ‘what grease for my rear hub’ is closed to new replies.
