devon_roadie – Member
“I’ve only tested the chest strap once and I was in 1080 mode so the affective field of vision is reduced from 170degrees to 120 or something. I found that because my riding position means my chest is pointing downwards, the camera physically didn’t have enough room to go as vertical as it needed to to get a decent view because my chest was in the way.”
The HD doesn’t fit perfectly on the chest mount unfortunately because of the different shaped case, bit of a slip from Gopro. Some people mount the camera upside down to get round it, I’ve added some foam to the back of the mount to tilt it a little, but Gopro just launched an adaptor which should sort it too (it’s just like the regular extension arms but with both sets of slots parallel so you only need one)
Variety’s the spice of life, single POV films are pretty dull IMO so bar mount, seatpost mount (same bracket for both) and helmet mount are nice to do occasionally. The rollbar mount works as a frame mount too but I’ve not had much luck with that and it can leave the camera very exposed in a crash.
