• This topic has 22 replies, 16 voices, and was last updated 10 years ago by Si.
Viewing 23 posts - 1 through 23 (of 23 total)
  • What frames are like the Cotic BFE?
  • rob-jackson
    as in slack/tapered head tube?
    Looking for a cheap second hand hardtail frame to run with new tapered pikes etc
    Rickos
    Later Ragleys use 44mm headtube iirc.
    parkesie
    Wanga
    rickon
    Soul 😉
    Is a Wanga really like a BFe? I had one, and it was a thin tubed 853, steepish light xc bike.
    Evil Sovereign
    Prince Albert
    On one 456 / summer season
    Ragley pig
    Ragley piglet
    Ragley Marley
    Stanton slackline
    parkesie
    Newer wangas are aluminium lt hardtails with tapered head tubes.
    wukfit
    Just get a BFe,
    #PedanticModeOn# Small e (pronounced beefy), and doesn’t have a tapered head tube #PedanticModeOff#
    Sorry it’s 21.09 where I am, and I’m literally drinking alcohol out a bucket 😀
    rob-jackson
    No it doesn’t your right but you can run tapered forks!
    wukfit
    You’re 🙂
    rob-jackson
    lol
    jambalaya
    Not sure how many second hand tapered head tube hardtails you’ll find. Probably only been producing them for 2-3 years and even then only in fairy small numbers.
    The BFe isn’t that slack angeled, same geo as the Soul but sturdier construction. My frame is from 2011 and Imrecall the tapered ones weren’t available yet.
    Rickos
    44mm head tubes will take a tapered fork though, so check those frames out too. No idea who has those in their hard tail line up though!
    And how cheap does it need to be?
    rob-jackson
    Dialled alpine mk3 #want
    dimitriscsd
    Evil Sovereign that was mentioned above would be the most fun choice… However it can’t take a tapered fork and there is no straight steerer pike…
    Damn marketing…
    Scapegoat
    mmmmbop… had a 1.5 headtube
    akak
    I have a large BFe frame to sell if you are interested, current generation in gritstone/black.
    wiggles
    Any excuse…
    G
    domcapper
    Newer oranges crushes have tapered and 650B
    souldrummer
    Those Alpines do look good in Orange. Mine is a Mk1, but I would recommend them, as I don’t think to much has changed between the various iterations.
    kelvin
    Lots of hardtails do now, don’t they? Including said BFe.
    tuskaloosa
    Privee Shan
    Fork : from 150 to 160mm travel
    Head tube angle: 66º
    though not sure if you would get them cheap and 2nd hand
    Rickos
    Kelvin – for sure, but he wants cheap second hand, which presents a limitation as most will be quite new I suspect and not cheap enough for Steptoe here.
    Genesis Alpitude has a 44mm headtube which might fit the cheap parameter, but probably not the right brand (darling!)
    toys19
    be careful, new BFe does, but they are still selling the classic BFe which does not.
    Si
    Orange Subzero… if your man enough…. 😉
The topic ‘What frames are like the Cotic BFE?’ is closed to new replies.
