Viewing 7 posts - 1 through 7 (of 7 total)
  • What frame will fit these forks?
  • djp7323
    Fox 36 Vanilla Rc2 forks 2010, 1.5 steerer, 175mm in length with star nut fitted.
    Made massive **** up! Got orange patriot frame 2004 from ebay and found these forks also on ebay.
    Dilema….. do i keep forks or the frame?
    Please help
    rOcKeTdOg
    any frame with a 1.5 headset compatible headtube
    HTH
    djp7323
    Yes i realise this… perhaps i should of been more specific.
    Anybody recommend a frame with a 1.5 headset compatible headtube? Want it to be an all mountain/ light downhill for a holiday in the alps.
    jam-bo
    175mm is pretty short.
    cynic-al
    what jambo said, I would guess 1.5 hs/stems are high stack heights?
    adsb
    mmmBop I reckon
    z1ppy
    You might just sneak them onto a C’dale Prophet, with no spacers. Mine has around 3cm of space above the headset, but it is a massive Woodman thing, lower stacked(?) 1.5 headsets maybe available. Opinion on whether 160mm forks suit the Prophet is kinda split though
The topic ‘What frame will fit these forks?’ is closed to new replies.
