doesnt mean its A. good B. advisable or C. good for the air quality around you .
But im ok jack.
” Do not slow / slumber burn. Do not “turn the stove down for the night”. There should be good visible flames in the firebox. Some stove users fill their stoves with wood and shut the air vent fully, immediately prior to retiring for the night, in order to keep the woodstove burning all night. This allows the stove to be rekindled in the morning simply by adding more fuel and opening up the air vents. However, this practice should be avoided at all costs – although the burn rate is reduced to such a level that the fire is still burning the following day. Instead of burning the wood to produce mainly carbon dioxide, water and heat, the process is reduced to conversion of the wood into heavy, tarry chemicals which are subsequently deposited on the insides of the flue or chimney. This is a very inefficient process – releasing only a small fraction of the available heat, and causes severe tarring of the flue/chimney which greatly increases the risks of chimney fire, and makes sweeping the chimney necessary more often.”
Ive grown up with parents/grandparents that did the same thing for years.
How ever if we always do the same thing we will always get the same results…. a nice smoggy mess. Gives stove users a bad name.
