Viewing 8 posts - 1 through 8 (of 8 total)
  • What exactly do I need for an Alfine set up?
  • duckman
    Right I have added the hub, rim,spokes and shifter to my basket, going on a geared Soul frame, so what else do I need?
    Houns
    Sprocket
    ash
    centrelock brake rotor
    ash
    chain tensioner
    I use one of these with the Alfine on my Alpine:
    http://www.chainreactioncycles.com/Models.aspx?ModelID=20325
    duckman
    Chain tensioner and sprocket added. What about crank, can I run a normal single or is there witchcraft involved in the fitting/chainline?
    ash
    er, just measure the chainline (mid axle at back to sprocket), and use trial and error with spacers to get the mid-BB to chainring distance the same
    johnners
    Fitting kit, if it’s not included with the hub. I think it’s usually listed seperately.
    Mister-P
    Fitting kit is not usually with the hub.
    To get the hub onto the bike and working you will need –
    Hub
    Fitting kit
    Sprocket (either Alfine or Nexus)
    Shifter (either Alfine or Nexus)
    Chain tensioner
The topic ‘What exactly do I need for an Alfine set up?’ is closed to new replies.
